August 29, 2026, 08:26:53 pm
Hoffman Amps Forum image Author Topic: Deluxe Reverb - 6L6's and more headroom  (Read 4109 times)
Offline skepasts
« on: December 12, 2021, 05:53:12 pm »
I handwired my Deluxe Reverb Reissue using a mojotone small parts kit and am looking to get some more headroom out of the amp. I play jazz and could use a bit more clean volume when playing with louder drummers or in bigger spaces.
I was planning on putting in 6L6s and new output and power transformers to achieve this. I believe a Vibrolux PT would drop right in. Unfortunately Allen is not selling the T026 output transformer anymore, so I was thinking of putting in a bandmaster output transformer 40W with 4/8/16 Ohm taps (my speaker is a 8 Ohm cannabis Rex)
Would those transformers work fine with 6L6's? Is there anything else I would need to change on the amp? Also, would running a solid state rectifier give me more clean headroom?
I don't care about resale value as I have already modded the amp.
Re: Deluxe Reverb - 6L6's and more headroom
« Reply #1 on: December 13, 2021, 01:27:43 am »
a Vibrolux PT would drop right in. …was thinking of putting in a bandmaster output transformer 40W with 4/8/16 Ohm taps (my speaker is a 8 Ohm cannabis Rex)
Would those transformers work fine with 6L6?
Yes, they will ‘work’ fine
« Reply #2 on: December 13, 2021, 03:04:14 am »
If you want to increase the power output, Vibrolux iron seems half a job, why not Super Reverb spec?
The PT, choke, OT and HT caps are the key components to uprate.
But a DR is a pretty nice amp to have available, be aware the changes will turn it into a heavy, unwieldy beast, and you may be able to pick up a real SR for a good price.
Offline jim
« Reply #3 on: December 13, 2021, 06:49:07 pm »
A Hammond 290CX drops right in. Then use a Vibrolux OT.  If you keep the DR OT you will need a 4 ohm speaker.  You will need to drill for the new OT mount and move the choke between the power tubes and the PI. You will increase the headroom by a small but noticeable amount.  Its expensive......Consider a new amp for jazz like a Roland or Twin if your needs are louder.  Jim
