August 01, 2026, 04:25:41 am
Hoffman Amps Forum image Author Topic: Crowncorder CTR5300  (Read 8224 times)
Offline uki
  • Hot Tube Hot Sound
    • Uki's Guitar Trip
Crowncorder CTR5300
« on: December 25, 2021, 04:25:56 pm »
I got this as an add to sweeten a really nice deal on another device!
I got this idea when checking it out, would be possible to convert it into a mini guitar amp with a leslie device using the motor,  If so how ?
https://soundcloud.com/ukiuki
Re: Crowncorder CTR5300
« Reply #1 on: December 25, 2021, 05:39:04 pm »
no
Offline uki
    • Uki's Guitar Trip
« Reply #2 on: December 25, 2021, 05:47:37 pm »
no
:sad:
What about using it for just a mini leslie cab ?
Offline uki
    • Uki's Guitar Trip
« Reply #3 on: January 26, 2022, 06:14:17 am »
I think there is use for the components at least, if they are working!
The transistors are 2SB75 (x6) similar to NKT275, some pedals use it. Like the EHX Germanium OD.
Code: [Select]
Type Designator: 2SB75
Material of Transistor: Ge
Polarity: PNP
Maximum Collector Power Dissipation (Pc): 0.15 W
Maximum Collector-Base Voltage |Vcb|: 25 V
Maximum Collector-Emitter Voltage |Vce|: 25 V
Maximum Emitter-Base Voltage |Veb|: 12 V
Maximum Collector Current |Ic max|: 0.1 A
Max. Operating Junction Temperature (Tj): 85 °C
Transition Frequency (ft): 0.8 MHz
Collector Capacitance (Cc): -
Forward Current Transfer Ratio (hFE), MIN: 55
Noise Figure, dB: -
Package: TO1
Code: [Select]
Type Designator: NKT275
Polarity: PNP
Maximum Collector Power Dissipation (Pc): 0.2 W
Maximum Collector-Base Voltage |Vcb|: 15 V
Maximum Collector-Emitter Voltage |Vce|: 15 V
Maximum Emitter-Base Voltage |Veb|: 5 V
Maximum Collector Current |Ic max|: 0.25 A
Max. Operating Junction Temperature (Tj): 90 °C
Transition Frequency (ft): 0.5 MHz
Collector Capacitance (Cc): 60 pF
Forward Current Transfer Ratio (hFE), MIN: 30
Noise Figure, dB: -
Package: TO1
