September 17, 2026, 09:21:47 am
Hoffman Amps Forum image Author Topic: Fender twin reverb  (Read 4098 times)
Offline Big chief
Fender twin reverb
« on: December 29, 2021, 12:23:41 pm »
Silver face twin with master volume  squeal reverb when pot is set above 7
Tried 3 different tubes retintion tube sockets cleaned all connections V3 is microphonic to the touch no matter what tube I use if I hold my hand on tip of guitar cable and touch V3
The squeal appears to go away any help would be helpful. Thanks
Offline Lectroid
Re: Fender twin reverb
« Reply #1 on: December 31, 2021, 10:28:05 am »
When you touch the cable, are you touching the cable itself or the plug?   A plug's metal cover is connected to ground and it's possible that your touch is creating a new ground path for the circuit that is currently missing.  I would look at the Reverb pot ground connection, and any other grounded components in that circuit path.  Chances are one of them's loose or got a cold solder joint.
Magis bos clocca!
Free Beer Tomorrow!
Offline Latole
« Reply #2 on: December 31, 2021, 01:56:46 pm »
Never, never touch a tube and other part of the amp in same time.
Offline Big chief
« Reply #3 on: December 31, 2021, 04:23:50 pm »
Bad ground at reverb pot thanks for your help
