September 16, 2026, 05:07:58 am
Hoffman Amps Forum image Author Topic: Pre-Amp Gates M5530 - Loud hum even with new caps  (Read 5869 times)
Offline spunko
« on: January 06, 2022, 06:23:23 pm »
Hello there! Happy new year!
I got my hands on this preamp "Gates M5530" which came with some caps already changed, but it had the two big original cans still in circuit.
When I tested it, inmediately started to hum pretty loud. I ordered some caps to replace the big cans, did the re-cap and the preamp still hums pretty bad.
Then I tested without tubes, even the rectifier out, and still makes a lot of hum, but less than with all the tubes installed.
I haven't found a diagram, just one which is pretty close from another Gates model.
What would you suggest to look for now?
Re: Pre-Amp Gates M5530 - Loud hum even with new caps
« Reply #1 on: January 06, 2022, 08:05:45 pm »
That's certainly not a guitar amp. Not really a modern mike-amp; anyway aren't your in/out plugs' sexes switched?
How are you listening to it? Direct connect speaker? Into a Line In? (a Mike IN??)
Does the knob do anything?
Offline Latole
« Reply #2 on: January 07, 2022, 03:30:10 am »
Hum with no tubes !
You have to check if all filter cap ( and the big can) are good even the "new" can and if they have not been installed reversed.
Without a 'scope it will not be easy.
Filter caps / power DC supply issue IMO
Some AC voltage go to the OT
« Last Edit: January 07, 2022, 07:17:35 am by Latole »
« Reply #3 on: January 07, 2022, 11:38:04 am »
Hum with no tubes !...
A piece of cable laying on the bench feeding a high gain mixer input will hum without tubes. Especially if grounds are broken.
Offline spunko
« Reply #4 on: January 18, 2022, 11:15:18 pm »
Hello, I got the virus, and everyone in my house too, so I got a time off.
It turned out to be 2 broken terminals on v1 tube socket. Replace them and now the horrible hum is gone. There is still a bit hum, but I think it is just part of this old piece of equipment.
Offline Latole
« Reply #5 on: January 19, 2022, 03:53:31 am »
Some shield wires may help.
Wiring dress are poor
