September 15, 2026, 10:39:46 pm
Hoffman Amps Forum image Author Topic: Some experienced eyes on this?  (Read 4341 times)
Offline jewishjay
  • Merrily on my way to nowhere in particular!
    • my Reverb store
« on: January 14, 2022, 05:11:56 pm »
I'm building a Brownface inspired harmonic tremolo amp. It's running and I love the tremolo sound, but I'm still tweeking.
Here's the voltages I read with a DMM right now. See anything of concern?
1. The bright switch is much too ice picky. Would I try a larger or smaller bright cap?
2. the NFB seems to have no effect, I think I want to lower the R. But I'm not even sure if I should use the 4 or 8 ohm tap. Is there some math I could learn?
Re: Some experienced eyes on this?
« Reply #1 on: January 14, 2022, 05:43:06 pm »
Experiment with the bright cap until you like it.
Use 56K and 4.7K in the NFB circuit. Look at some 6G?? schematics.
Offline ac427v
« Reply #2 on: January 14, 2022, 06:46:39 pm »
512 volts on the plates of the output tubes is beyond my experience.
Offline echuta13
  • Elder God
« Reply #3 on: January 14, 2022, 07:30:55 pm »
Maybe try a 100pF or no bright cap.
"When choosing between two evils I always like to try the one I've never tried before."
Offline BrainDeadAmps
  • Trial and error
« Reply #4 on: January 14, 2022, 11:05:11 pm »
Looking at several 6gx circuits, most have a split plate load resistor on v1B. how is the tremolo with the volume cranked?
Offline ghostinthescope
« Reply #5 on: January 15, 2022, 08:47:31 pm »
Like Sluckey said the negative feedback shunt resistor probably wants to be 4.7k. I’d keep the 100k as is, since thats what the 6gx circuits use. I recently built an amp with this same harmonic tremolo circuit as well as a bias vary trem and reverb. I definitely did a lot of head scratching and tweaking to get it working well.
« Last Edit: January 15, 2022, 09:08:07 pm by ghostinthescope »
