September 15, 2026, 10:03:59 pm
Hoffman Amps Forum image Author Topic: Reverb Problem  (Read 6349 times)
Offline Travis8
Reverb Problem
« on: January 17, 2022, 10:00:08 am »
Hi everyone!
I have one 2rock amp and when I turn up reverb to max setting, it´s sound like if it was at 3 or 2. Like very subbtle reverb.
someone know how can I solve this?
some indications?
thanks!!
Re: Reverb Problem
« Reply #1 on: January 17, 2022, 10:02:26 am »
does 3/4 MAx setting sound good?
Offline 66Strat
Re: Reverb Problem
« Reply #2 on: January 17, 2022, 10:06:07 am »
Bad tube?
Regards,
JT
Offline Travis8
Re: Reverb Problem
« Reply #3 on: January 17, 2022, 10:20:45 am »
It´s sounds good but reverb is very subtle even to the max settings.
Under max settings almost no reverb sound
Offline echuta13
  • Elder God
Re: Reverb Problem
« Reply #4 on: January 17, 2022, 11:58:02 am »
Sounds like a faulty pot?
"When choosing between two evils I always like to try the one I've never tried before."
Re: Reverb Problem
« Reply #5 on: January 17, 2022, 12:23:32 pm »
I'd head down 66's road and roll in a few different tubes.
what amp?
what schematic?
Re: Reverb Problem
« Reply #6 on: January 17, 2022, 12:25:54 pm »
I'd start by obtaining a schematic.
Offline Travis8
Re: Reverb Problem
« Reply #7 on: January 17, 2022, 01:28:14 pm »
I will take a look at the pot and tubes
Re: Reverb Problem
« Reply #8 on: January 17, 2022, 01:52:41 pm »
Some context is needed, eg is this your amp that you’ve had for a while and used to have plenty reverb?
Find some reviews, demos. It’s kinda essential to be sure that the reverb level is unusual, rather than normal.
« Last Edit: January 17, 2022, 01:54:42 pm by pdf64 »
Offline Travis8
Re: Reverb Problem
« Reply #9 on: January 17, 2022, 03:13:45 pm »
Reverb use to be plenty and big. Know It´s like I can´t get more than 1/2 but when it´s maxed
Re: Reverb Problem
« Reply #10 on: January 17, 2022, 08:38:30 pm »
Two Rock  https://www.two-rock.com/
The first thing I saw on their site is this quote about "classic reverb signature". So it should be "special", not a pen-spring in front of the speaker.
Reverbs usually work, hum, or don't-work. To be way down on volume is real strange. There's many ways (not just the Fender way) to do reverb. I suggest you ask Two-Tone for hints, clues, or even service information.
