September 15, 2026, 12:08:08 pm
Hoffman Amps Forum image Author Topic: AC15 Volume Issues  (Read 7108 times)
Offline ebulakowski
AC15 Volume Issues
« on: January 27, 2022, 11:02:14 am »
Hey gang.
I have a 90's AC15 on the bench. I am getting hum that comes through when the volume is up.
I am also experiencing issues with the volume control. It acts normal in the first 30% of its sweep. Then I experience a strong volume drop for most of the remaining sweep.
No crackle and the pot measures normal. I'm working with new tubes. All other controls function predictably and moving the vol to zero gets rid of the hum.
What should I be looking for?
Offline Latole
Re: AC15 Volume Issues
« Reply #1 on: January 27, 2022, 12:50:54 pm »
Issue with input jacks ; check ground,
Filter caps
Any mods in the amp ?
« Reply #2 on: January 27, 2022, 01:05:29 pm »
Oscillation. Which leads back to Latole's question.... what has changed?
Offline ebulakowski
« Reply #3 on: January 27, 2022, 02:22:35 pm »
Filter caps
Thanks guys. The amp is stock. As far as I can tell I am the first one inside. Jacks are secure. All of the caps tested withing spec on a DMM, but I certainly haven't ruled them out as a potential problem. I just wanted to see if there were any other things I should check before changing them out.
Offline Latole
« Reply #4 on: January 27, 2022, 02:35:48 pm »
Filter caps ; check AC voltage, yes AC not DC
Have a look here ;https://el34world.com/Forum/index.php?topic=28461.new;topicseen#new
Offline ebulakowski
« Reply #5 on: January 28, 2022, 11:17:31 am »
Thanks guys. I need to order some caps and then i'll dig in.
Offline ebulakowski
« Reply #6 on: February 01, 2022, 04:53:47 pm »
I'm still struggling through this one. I read the entire linked thread. I Tested for AC voltage. My readings after a moment of contact on the plates was <.005vac and usually then crept down to .001-.002vac.
I have replaced all of the filter caps. The volume know continues with the same problem. It act/sounds similar to when I have bias transistors in pedals. a whooshing/static when turning, and only a small window of function. And I get a smooth resistance change with a meter.
Offline ebulakowski
« Reply #7 on: February 07, 2022, 02:47:28 pm »
any other insights out there? I'm still getting volume drop after about 30-40% rotation on the volume pot.
Offline valvetones
« Reply #8 on: February 12, 2022, 01:43:34 am »
Check the potentiometer terminals for DC voltage. If you have any DC on any terminals, follow the lead back to the coupling cap that is connected to it. It may be leaky.
Just something I would do.
Haven’t looked at a schematic, don’t know ac15 layout.
Just a hunch
Offline ebulakowski
« Reply #9 on: February 14, 2022, 10:50:37 am »
Just a hunch
Thanks for this suggestion. Yes, I found VDC on the two non grounded lugs of of the volume pot. I will look into swapping the caps in that area. I imagine C17 and C27 are the ones to look at from the schematic above?
Offline dwinstonwood
« Reply #10 on: February 14, 2022, 11:30:38 am »
ebulakowski, please note that the schematic you posted in your first post has at least one area that's missing from the drawing.
There is a connection between "BA" - the second, or "B" annode, pin 6 - of the second triode of the first input tube to R8, the 100K plate load resister.
I found and have attached a different copy of your schematic that shows this connection.
Offline ebulakowski
« Reply #11 on: February 17, 2022, 09:48:37 am »
Thank you for noticing that and sharing a better schematic!
Offline ebulakowski
« Reply #12 on: February 24, 2022, 01:12:17 pm »
Just a hunch
Thanks to everyone for the help! valvetones hunch was right. I replaced c17 and c27 and i'm back in business!
Offline valvetones
« Reply #13 on: March 01, 2022, 10:59:50 am »
Excellent. Stay groovy
