September 14, 2026, 03:58:26 pm
Hoffman Amps Forum image Author Topic: 100 iron in 50 watt build?  (Read 4812 times)
Offline joesatch
  • save me from myself.
« on: January 27, 2022, 03:22:30 pm »
Question, i have a 100 watt transformer set for marshall but wanted to build a 2204 with it (50 watts). Would i build this normally and just put the OT 4ohm tap to the 8ohm speaker jack and 8ohm OT tap to the 16ohm speaker jack? Would i need to change anything else in the circuit (aside from possibly upping the dropping resistors)
Re: 100 iron in 50 watt build?
« Reply #1 on: January 27, 2022, 03:35:07 pm »
Should work. You will need to connect the PT according to the 2203 schematic.
Offline uki
  • Hot Tube Hot Sound
    • Uki's Guitar Trip
« Reply #2 on: January 27, 2022, 04:21:32 pm »
I would not use a 100w OT for a 50w amp, its not about if will work or not, but because the OT could be used for a 100w amp. You could build a 100w amp with that OT !  I would !!  I think, matching parts as best as possible gives better results. Not trying to change your mind but think about it, maybe it could be a good challenge !
https://soundcloud.com/ukiuki
Offline thetragichero
« Reply #3 on: January 27, 2022, 07:37:24 pm »
keep in mind that a 50w amp will not load the 100w power transformer nearly as much so you will likely have a much cleaner amp
really it'll be a completely different amp since your power supply voltages will all be higher
Offline Bieworm
  • I like it loud!
« Reply #4 on: January 28, 2022, 04:58:26 am »
I'd do the 100W too...
They are louder, but not twice the volume.. rather like 10% area.
If you get to crank a 50W then you could also crank  a 100W. At that volume you'd hardly hear the difference.
PLUS then it will sound 100% marshall,  for they were initially designed as 100W amps😄👍
« Reply #5 on: January 28, 2022, 09:18:16 am »
I'll be the dissenter and say a 100W OT in a 50W build is just fine.
I used a set of iron meant for a Marshall 100 in a 30-ish watt PP self biased amp
my OT had UL taps and used them - EL34's for the PA,  plexi-ish pre.
It's the only amp I've designed that got unanimous thumbs up from the test guitarists, and they're a tough crowd!
the ONLY complaint  "you can't screw up, you will ear every missed note and it will sing out like a slapped face"  :icon_biggrin:
