September 15, 2026, 11:41:31 pm
Hoffman Amps Forum image Author Topic: Sizing a reservoir Cap  (Read 4647 times)
Offline joesatch
  • save me from myself.
« on: February 03, 2022, 09:28:43 am »
Reading valve wizard. I'm trying to spec the resistors used when running two Caps in series. I have (2) 220uf 350v Caps so i will run these in series. The even-ing resistors can be calculated but I'm not sure what 50/C means in the wording. Is it 50/ Capacitance?  What resistors would i use in this case?  Also from what i understand it is okay to over-spec the reservoir cap if using diode rectification (will just be a stiffer sound).
https://www.mouser.com/ProductDetail/Nichicon/LGN2V221MELA30?qs=4lWw5qRttGKUm4BfyCZuJQ%3D%3D
« Last Edit: February 03, 2022, 09:31:36 am by joesatch »
Offline thetragichero
Re: Sizing a reservoir Cap
« Reply #1 on: February 03, 2022, 09:32:39 am »
50/.00022 = 227k
i usually just use220k metal oxide resistors regardless of cap value
Offline joesatch
« Reply #2 on: February 03, 2022, 09:45:24 am »
50/.00022 = 227k
Okay so 50/farad  thanks! :l2:
