September 15, 2026, 02:29:01 pm
Hoffman Amps Forum image Author Topic: Is a 3.5k OT ok for 6v6s?  (Read 4918 times)
Offline A13X
« on: February 05, 2022, 01:00:35 pm »
Hello all, I’ve been lurking/learning from this forum for a while now.
I was hoping someone could help me with a problem I’m stuck on.
I have a kit amp designed around the bassman (25watts) that included a 3.5k 25 watt OT with 3 secondary taps.
Is it acceptable to go to JJ6V6S tubes with this OT?
Thanks so much everyone!
« Last Edit: February 05, 2022, 04:03:53 pm by A13X »
Re: Is a 3.5k OT ok for 6v6s?
« Reply #1 on: February 05, 2022, 01:39:02 pm »
Keep it simple. I would just leave the 6L6s in the amp. Adding 300mA load on the filament string is not going to hurt anything.
Offline A13X
« Reply #2 on: February 05, 2022, 03:54:57 pm »
Ok , thank you! The OT is rated for 3A. When I looked it up adding the tube would put me at 3.12A. If this isn’t a concern then I’ll keep them. I don’t know what the acceptable % over the rating I can safely go…
 I guess it would have been easier to ask that question first [facepalm]
Offline A13X
« Reply #3 on: February 05, 2022, 04:04:53 pm »
Keep it simple.
I edited so it would be, my apologies
« Reply #4 on: February 05, 2022, 04:21:33 pm »
When you add the extra tube measure the filament voltage between pins 2 and 7 of one of the 6L6 sockets. What have you? I would not be concerned if it is still at least 6VAC.
Most new PTs will be putting out more than 6.3VAC. I would not be surprised if adding 1 more tube still yields more than 6.3VAC.
« Last Edit: February 05, 2022, 04:23:49 pm by sluckey »
