August 01, 2026, 03:49:23 am
Hoffman Amps Forum image Author Topic: Fender Twin Reverb  (Read 17192 times)
Offline Big chief
Fender Twin Reverb
« on: February 07, 2022, 10:22:35 am »
Silverface believe to be 1975 with master volume low volume
Have replaced power tubes and pre amp tubes
Voltage V1 pin1 210 pin6 213 V2 pin1 209 pin6 208 V3 pin1 400 V4 pin1 150 pin6 150
V5 pin1 338 pin 6 337 V6 pin 1 300 pin6 287 V 7-8-9-10 pin 3 429 pin6 424
With volume pots at full open very little sound have used 2 different speaker cabinets 4 ohm
Any help would be great. Thanks
Re: Fender Twin Reverb
« Reply #1 on: February 07, 2022, 10:31:23 am »
got a scope?
what's the bias VDC on the grids of the PA tubes?
does the amp have a "pre-amp out" jack?
If so, can you feed that out into another amp/mp3 player?
« Reply #2 on: February 07, 2022, 10:45:13 am »
Does the issue affect both channels?
What痴 the V6 cathode voltage, pin3&8?
Offline Latole
« Reply #3 on: February 07, 2022, 03:27:11 pm »
What is the heater voltage at each tube ?
Any mod in the amp ?
Offline uki
  • Hot Tube Hot Sound
    • Uki's Guitar Trip
« Reply #4 on: February 07, 2022, 06:18:21 pm »
If you could provide the schematic it would be a great help.
https://soundcloud.com/ukiuki
« Reply #5 on: February 07, 2022, 06:51:44 pm »
Contact plexi50. He does a lot of repair work in your area.
Offline Big chief
« Reply #6 on: February 07, 2022, 08:01:08 pm »
Grids V1 pin 2 0 pin7 .03 V2 pin2 0 pin7 .03 V3 pin2 0 pin7 .06 V4 pin2 0 pin 7 .02
V5 pin2 12.9 pin7 12.2 V6 pin2 82 pin7 76
V7 pin8 0 pin3 424 V8 pin8 0 pin3 425 V9 pin8 0 pin3 429  V10 pin8 0 pin3 429
FYI plex is a good friend and helps me
Offline Big chief
« Reply #7 on: February 07, 2022, 08:05:41 pm »
I do not have a scope  no amp out jack
I知 retired and love to work on old amps as I have played old country music for 71 years
Offline Latole
« Reply #8 on: February 08, 2022, 03:29:10 am »
https://ampwares.com/amplifiers/fender-silverface-twin-reverb/#
Yesterday ; where is the answer ?
« Last Edit: February 08, 2022, 03:32:13 am by Latole »
Offline Latole
« Reply #9 on: February 08, 2022, 03:46:00 am »
You need a scope and signal generator ; A basic tool to work in a amps.
Without these tools you will only be able to fix the easy problems.
If you don't have these basic tools, you have to compensate with a solid knowledge in electronics
« Last Edit: February 08, 2022, 04:28:56 am by Latole »
Offline Big chief
« Reply #10 on: February 08, 2022, 06:30:04 am »
I have a fair knowledge of tube amps I mostly do the easy stuff
Heater voltages V1 2.3 V2 2.3 V3 3.0 V4 2.3 V5 3.0 V6 3.0
 V7 3.5 V8 3.5 V9 3.1 V10 3.5
Does not appear to have any mods  this amp has been mistreated imo
I知 trying to help a frien
Offline uki
    • Uki's Guitar Trip
« Reply #11 on: February 08, 2022, 08:50:07 am »
Voltages
V1 pin1 210  pin 2 0  pin6 213  pin7 .03
V2 pin1 209  pin2 0   pin6 208  pin7 .03
V3 pin1 400  pin2 0   pin6 ?    pin7 .06
V4 pin1 150  pin2 0   pin6 150  pin7 .02
V5 pin1 338  pin2 12.9 pin6 337 pin7 12.2
V6 pin1 300  pin2 82  pin6 287 pin7 76
V7 pin3 424 pin6 424 pin8 0
V8 pin3 425 pin6 424 pin8 0
V9 pin3 429 pin6 424 pin8 0
V10 pin3 429 pin6 424 pin8 0
Heater voltages
V1 2.3
V2 2.3
V3 3.0
V4 2.3
V5 3.0
V6 3.0
V7 3.5
V8 3.5
V9 3.1
V10 3.5
Offline Latole
« Reply #12 on: February 08, 2022, 08:53:07 am »
They are low ; too low .
Voltage reading are from the ground ?
You should read 6.3 volts between pins 5/4 and 9 on preamp tubes
From ground  you must have 6.3 / 2 =3.XX not 2.3
« Reply #13 on: February 08, 2022, 09:45:01 am »
Thank you uki for doing this, much easier to read now!   :icon_biggrin:
Voltages
Heater voltages
V1 2.3
V2 2.3
V3 3.0
V4 2.3
V5 3.0
V6 3.0
V7 3.5
V8 3.5
V9 3.1
V10 3.5
Offline Latole
« Reply #14 on: February 08, 2022, 09:46:29 am »
Do you know V7,8,9,10 pin 8 are ground ?
0 volts is right
« Reply #15 on: February 08, 2022, 09:49:12 am »
Big chief, you need to measure the heaters across their pins, 4/5 - 9, 2 - 7 and not 1 meter probe to a heater pin and the other meter probe to ground.
Offline Latole
« Reply #16 on: February 08, 2022, 09:53:26 am »
Voltages
Heater voltages
V1 2.3   = 4.6  heater voltage  :BangHead:
V2 2.3   = 4.6
V3 3.0   = 6
V4 2.3  = 4.6
V5 3.0  =  6
V6 3.0.  = 6
V7 3.5   = 7 !!!!
V8 3.5   = 7  !!!
V9 3.1    = 6.2 Good
V10 3.5 = 7
If you read 7 volts at V8 , you must read 7 volts at V9 not 6.2  :w2:
Tubes are wired in parallel
Something wrong with your test meter or amp wiring or.......... ?
Offline Latole
« Reply #17 on: February 08, 2022, 09:55:09 am »
That is what I wrote 1 hour earlier........
Offline Big chief
« Reply #18 on: February 08, 2022, 09:57:42 am »
Pins 4-5 on this amp are tied together
At pilot light from ground on each side 3.1 Across the pilot light 6.2
Pin 8 to ground 0
I have check plate resistors none out of specs  next check coupling caps for dc current I guess
Offline Latole
« Reply #19 on: February 08, 2022, 10:04:21 am »
Pin 8 to ground 0
Yes 4 and 5 are always wired together, that is what we mean when we wrote 4/5 and pin 9
Read with voltmeter at pin 9 ansd pin 4 or 5 . you should read 6.2 as pilot light
Offline Latole
« Reply #20 on: February 08, 2022, 10:07:16 am »
uki wrote ;
« Reply #21 on: February 08, 2022, 10:16:04 am »
....Across the pilot light 6.2
That fine, but because you had lower readings before on the 1st/2nd preamp tubes, best measure that 1st preamp tube again across pins 4/5 and 9.
Offline Big chief
« Reply #22 on: February 08, 2022, 10:22:30 am »
Found some frayed wire going to replace all heater wire then recheck voltages
Thanks for all your time and help
Offline Big chief
« Reply #23 on: February 08, 2022, 05:02:25 pm »
Repaired heaters wires to all tubes
Have 6.2 on all heaters set power tube bias at -49  all at once all tubes lost power but pilot light stayed on    Now don稚 know what to do
« Reply #24 on: February 08, 2022, 05:06:43 pm »
as in the filaments went out or the B+ went to zero?
Offline Big chief
« Reply #25 on: February 08, 2022, 05:32:33 pm »
I found the problem loose heater wire  my fault.
However I have dc voltage through the coupling caps should I replace them .1uf
« Reply #26 on: February 08, 2022, 05:55:49 pm »
Those caps are supposed to have dc on each side.
Offline Latole
« Reply #27 on: February 09, 2022, 02:43:20 am »
Congrat !
Answer #3 february 7
Offline Big chief
« Reply #28 on: February 09, 2022, 06:56:24 am »
Have checked ohm痴 on all resistors none seam to be more than 10%
Rechecked voltages
V1 pin1 219 pin6 227 V2 pin 1 222 pin6 228 V3 pin1 414 pin6 412 V4 pin 1 230 pin6 232
V5 pin 1 353 pin6 353 V6 pin1 312 pin6 301
V7 pin3 439 pin6 403 V8 pin3 439 pin6 402 V9 pin3 434 pin6 434 V10 pin3 435 pin 6 433
6.2 to all heaters
Power tubes are new and checked  pa tubes test good on my tube tester have replaced some and moved around   Chopped stick board no loose connections   What am I missing  still very low volume
Offline Latole
« Reply #29 on: February 09, 2022, 07:01:11 am »
Many tube tester are not reliable, best is to pu know good preamp tubes
« Reply #30 on: February 09, 2022, 08:00:06 am »
Examine the speaker jacks. Is the plug in the correct jack? Do you have the simple two lug jack for the external speaker? Or is it the more complicated jack with transfer circuit switch contacts as found in later TRs?
You still have not provided a correct schematic for your amp. There are more than one TR circuit with a MV and we cannot guess which one based on the little info you have provided.
Offline Latole
« Reply #31 on: February 09, 2022, 08:06:19 am »
Third time we ask  :BangHead:
Offline Big chief
« Reply #32 on: February 09, 2022, 08:49:43 am »
I知 using schematic Twin reverb Aa270 layout
I search this web site a d printed the schematic that I知 using
I have not been able to find the exact schematic for this amp yet and I have searched all I know
Have used 2 different speaker cabinets with 4 ohm and have checked and cleaned the 2 jacks that are on the chassis I値l try my best to take photo of the chassis that I知 working on
This amp is a mid 70痴 with master volume
Offline Latole
« Reply #33 on: February 09, 2022, 08:53:00 am »
Wrong layout ; no master volume
Did you look to my link ? Answer #8
All are there.
Can you read schematic ?
Layout is not good to trouble shouting.
« Last Edit: February 09, 2022, 08:55:55 am by Latole »
Offline Big chief
« Reply #34 on: February 09, 2022, 10:07:45 am »
Yes I can read schematic  I hope I answered your # 8
I am still looking for schematic with master volume now I知 trying to send photo of chassis
Some times I get a little confused
Offline uki
    • Uki's Guitar Trip
« Reply #35 on: February 09, 2022, 10:37:47 am »
Please post more pictures from the other side of the chassis, as well front and back faces, someone might spot the schematic for you with that info !
Oh and about the heater wires, make sure the same wire is in the same pin number for all sockets, unless the schematic says otherwise.
« Last Edit: February 09, 2022, 10:40:11 am by uki »
Offline Latole
« Reply #36 on: February 09, 2022, 11:43:13 am »
Show us the right schematic.
Schematic is the first thing you need before working in a amp .
« Reply #37 on: February 09, 2022, 12:11:45 pm »
Look in Hoffman's schematic library. It's there. Does your amp's MV have a push/pull switch on it? If so, look for that schematic. If not, look for the MV without the push/pull switch.
« Reply #38 on: February 09, 2022, 01:15:41 pm »
The 470ohm unbypassed V3 cathode resistor shown in the photo indicates that this may be the appropriate schematic https://el34world.com/charts/Schematics/files/Fender/Fender_twin_reverb_sf_100_schem.pdf
The previous version without the pull boost has a bypassed 2k2 V3 cathode resistor https://el34world.com/charts/Schematics/files/Fender/Fender_twinreverb_sf_100_mv_noboost.pdf
« Last Edit: February 09, 2022, 02:07:01 pm by pdf64 »
Offline Latole
« Reply #39 on: February 09, 2022, 01:55:13 pm »
You have a very good eyes
« Reply #40 on: February 09, 2022, 02:03:14 pm »
I was getting desperate trying to find something to move this along!  :laugh:
Offline Latole
« Reply #41 on: February 09, 2022, 02:06:46 pm »
 :occasion14:
Offline Big chief
« Reply #42 on: February 09, 2022, 05:05:20 pm »
More Photos
Offline Big chief
« Reply #43 on: February 09, 2022, 05:07:08 pm »
More Photos
« Reply #44 on: February 09, 2022, 05:49:51 pm »
The resolution of those photos is inadequate for them to be much use. We need to be able to zoom in and get detail, not mush.
Offline Big chief
« Reply #45 on: February 09, 2022, 07:22:30 pm »
hope these photos are better
Offline Big chief
« Reply #46 on: February 09, 2022, 07:24:22 pm »
one more time
Offline Latole
« Reply #47 on: February 10, 2022, 02:49:15 am »
What is that pot ?
Offline Big chief
« Reply #48 on: February 10, 2022, 05:26:32 am »
That pot hum balance for power tubes to the best of my knowledge
Could I possibly have a weak out put or choke problem it seams no matter what I do the volume does not change I have replaced every tube even power tube sockets
Offline Latole
« Reply #49 on: February 10, 2022, 05:29:58 am »
Without the right ( and basic amps repair  ) tools ; scope and audio generator....... good luck
