September 16, 2026, 11:18:45 pm
Hoffman Amps Forum image Author Topic: What kind of meter is it?  (Read 4627 times)
Offline uki
  • Hot Tube Hot Sound
    • Uki's Guitar Trip
« on: February 09, 2022, 01:03:15 pm »
Hey guys !
I got this from an old electronic kit. It had several things, pots, LEDs, bunch of coils to hold components, a small protoboard, ferrite coil, a seven segment display, push buttons,
and the meter in the pictures.
It does read 1.6k ohms. In the display it says I/V so current and voltage.
Does anybody know what kind of meter is this? A galvanometer ?
Thanks in advance !
« Last Edit: February 09, 2022, 01:30:11 pm by uki »
https://soundcloud.com/ukiuki
Re: What kind of meter is it?
« Reply #1 on: February 09, 2022, 03:48:53 pm »
> ? A galvanometer ?
Yes; except a "galvanometer" is an expensive antique. This is a small cheap current meter. To read real volts you add a series resistor.
Get a 9V battery and a 10k resistor. Wire like this. TAP the last connection to be sure it won't SLAM the meter. Does the meter go up to 77.6% (3/4) of full scale? (Reverse connections if needed.) Then it is a 1milliAmp meter. (If it slams, try 100k, but a 100uA meter is unlikely in a child's project kit.)
« Last Edit: February 09, 2022, 03:52:57 pm by PRR »
Offline uki
    • Uki's Guitar Trip
« Reply #2 on: February 10, 2022, 08:12:41 am »
The device is cheap indeed, the needle was stucking, loosing the screw a bit did the trick, 10k resistor did slam it, 100k did work, the needle go up to about to the 100 and go back to about 1/2 of the full scale. With two 100k in series, it goes up about 1/4 of full scale.
With a 48k it did go up full scale. The needle always go up and back a bit every time the battery is connected.
« Last Edit: February 10, 2022, 08:46:51 am by uki »
Offline uki
    • Uki's Guitar Trip
« Reply #3 on: February 11, 2022, 08:14:45 am »
I did read the galvanometer resistance again (about 1655 ohms), with a working needle now, and it does move to about 3/4 of the full scale while reading with a DMM at 2k ohms scale, at 20k goes down to 1/4.
So 48k means about 50uA, or 5mA ?
Found this http://hyperphysics.phy-astr.gsu.edu/hbase/magnetic/ammet.html
What if it is used with high voltage as ammeter, does the shunt resistor need a bigger value? how to find the value?
« Last Edit: February 11, 2022, 09:51:31 am by uki »
