September 16, 2026, 12:52:35 pm
Hoffman Amps Forum image Author Topic: Robinette AA1164 with tremolo and reverb deleted  (Read 5193 times)
Offline isaac_teller
« on: February 13, 2022, 11:49:13 am »
Hello. I've built this exactly as per the schematic with the addition of a passive efx loop between the 0.02 cap and the 10M/10pf(before the wet/dry split). When a pedal is used in the loop there is a significant power output reduction along with distortion. Is the 1M reverb load and 500pf reverb filter causing this? Thank you.
https://robrobinette.com/images/Guitar/AA1164/AA1164_Princeton_Reverb_Delete_Reverb_and_Tremolo_Schematic.jpg
« Last Edit: February 13, 2022, 11:56:22 am by isaac_teller »
Re: Robinette AA1164 with tremolo and reverb deleted
« Reply #1 on: February 13, 2022, 12:48:02 pm »
No, it’s the disparity in signal levels, between the insert point and the fx.
« Reply #2 on: February 13, 2022, 02:28:24 pm »
Thank you.
« Reply #3 on: February 13, 2022, 05:00:56 pm »
If you’re sure an fx loop (especially a passive one) would be beneficial, then the 3rd stage grid circuit may be a better insert point, as the signal level is about 1/8 of that at the 2nd stage anode. But the send impedance is even higher.
Or after the volume control.
« Reply #4 on: February 13, 2022, 06:29:29 pm »
....loop between the 0.02 cap and the 10M/10pf(before the wet/dry split)
I do not see a '10M'?
Guitar FX level is similar to guitar level, so you can use FX in the cord without a loop. Here V1 has gain of 50, tone stack has "gain" of 1/5, V1B has gain of 50.... there is gain of 500 from guitar to your loop send. No FX unit wants an >10V signal, and can't output that much. On the other side, the 3.3M:470k divider cuts-down whatever comes out of the FX unit. It's pretty lame by that point.
Signal at grid of 3B is like 0.2V, a pretty hot but plausible level for guitar effects. The 411k send impedance is a bit high to go far. Try the 3.3Meg:470k divider as 330k:47k for a more reasonable send. (Try with and without a 100p cap; length of Send cable will matter.) You should have a 1Meg grid-leak because you can't depend on FX to leak DC.
« Reply #5 on: February 14, 2022, 12:26:17 am »
I meant 3M3/10pf. I'll try the 330k/47k.
« Last Edit: February 14, 2022, 12:31:39 am by isaac_teller »
