September 17, 2026, 07:22:42 am
Hoffman Amps Forum image Author Topic: Randall LB103 ; need schematic  (Read 10265 times)
Offline Latole
« on: February 18, 2022, 03:35:05 am »
Hello,
 A customer has just brought me a Randall LB103 head to repair.
I am looking for the schematic of this amp, I am unable to find it.
I just wrote to Randall.
Someone has this schematic ?
Thank you
« Last Edit: February 18, 2022, 03:41:06 am by Latole »
Offline uki
  • Hot Tube Hot Sound
    • Uki's Guitar Trip
Re: Randall LB103 ; need schematic
« Reply #1 on: February 18, 2022, 09:24:49 am »
I did look into it , all I could find is the user manual, even used an alternative search engine.
Look in the left side there is a list of hosts of this engine under URL.
https://searx.space/
https://soundcloud.com/ukiuki
Offline Latole
« Reply #2 on: February 18, 2022, 09:37:54 am »
Thank you, I found user manual too
I talk and wrote to Randall amp service in Canada.
I hope they will send me the schematic.
Offline Latole
« Reply #3 on: February 18, 2022, 01:27:15 pm »
Receive the answer; they don't have schematic  :BangHead:
Could this be the reason why a new customer just brought me a Randal head that has been to the authorized service department twice, a big box that I won't name and the repair doesn't last.
I will try to do better
Offline uki
    • Uki's Guitar Trip
« Reply #4 on: February 18, 2022, 01:34:43 pm »
  :cussing:
How are people supposed to fix their amps ?! Well it isn't impossible but the schematic does help a lot.
Offline Latole
« Reply #5 on: February 19, 2022, 04:56:10 am »
Is that why the Service Center do not do a good job on the amp ?
I found intermittent heater supply on the four EL34
More coming.
Offline Latole
« Reply #6 on: February 19, 2022, 06:12:14 am »
Only simple issues do not require schematics
The amp I'm talking about ;
Offline uki
    • Uki's Guitar Trip
« Reply #7 on: February 19, 2022, 07:49:56 am »
Looks to be a complex amp, lots of knobs, 2 boards!!
Offline Latole
« Reply #8 on: February 19, 2022, 08:49:58 am »
Yes very complex with voltage regulators, Op Amps and 3 boards very hard to work on.
Offline Latole
« Reply #9 on: February 19, 2022, 01:50:23 pm »
I think I found and fixed the problem, (at least one problem ) time will confirm it, the amp is under test.
At first the amp was not playing, no sound, pilot lamp on
Observation: the 4 EL34 tubes were not lit and had no heater voltage. The preamp tubes; normal heater voltage
History summary;
The connector (photo yellow arrow) is intermittent on 6.3 VAC red and white wires and it comes from the connector itself; bad crimped wires?
I simply ran 2 new wires( black arrows at right )  from the 6.3 volt AC (see red arrow on the left on the pictures) to the sockets of the first EL34
« Last Edit: February 19, 2022, 01:56:26 pm by Latole »
Offline uki
    • Uki's Guitar Trip
« Reply #10 on: February 19, 2022, 02:12:42 pm »
Seen like an easy fix! What else remains?
Is that connector(yellow arrow) soldered to the board or attached to a socket?
Offline Latole
« Reply #11 on: February 19, 2022, 02:17:14 pm »
Socket solder on the board
Offline Latole
« Reply #12 on: February 19, 2022, 02:27:09 pm »
Yes an easy fix after determining that the preamp lamps are DC powered and only the EL34's were 6.3 AC powered .
I don't want to cause a short circuit and have more problems.
And knowing that repairing the connector in a sustainable way was not an option.
Most of the time, to fix an amp is easy .....after you know what to do.
« Reply #13 on: February 19, 2022, 02:33:18 pm »
Yeah. That's why they pay you the big bux!    :l2:
« Reply #14 on: February 19, 2022, 02:48:03 pm »
Some years ago I got a Fender Squier 10 at a Flea Market
The amp was working (only a blown fuse) but it had damaged Grill Cloth and 115V PT (Here we have 240V line)
I asked to the Fender Support for the schematic (as to put it in my archive, as I've the amp)  but the answer was the same, we have no schematic (even now I don't know who really build the amp), however they sent to me a new 240V PT and a baffle with grill cloth and Fender Label all for free
« Last Edit: February 19, 2022, 02:50:53 pm by kagliostro »
Offline uki
    • Uki's Guitar Trip
« Reply #15 on: February 19, 2022, 03:00:55 pm »
preamp lamps are DC
Is that to reduce noise/hum?
« Reply #16 on: February 19, 2022, 03:59:16 pm »
...Fender Squier 10 ....we have no schematic ....
Internet does.
https://archive.org/details/squier-fender-sp-10-schematic_202010/mode/1up
Sells 2nd-hand for about $30 here.
« Reply #17 on: February 19, 2022, 05:41:31 pm »
I apologize with Latole for the OT
Many Thanks PRR
At that time it was impossible to find one, or, at least, it was impossible for me  :icon_biggrin:
I've just put a copy on my database
Thanks again
Offline Latole
« Reply #18 on: February 20, 2022, 03:16:04 am »
preamp lamps are DC
Yes.
Offline Latole
« Reply #19 on: February 20, 2022, 03:22:26 am »
Internet does.
Fender schematics are probably the easiest to get from several sources.
I've already seen that for recent amps, schematics may be less available or not yet published, maybe it was the case for this Squier 10 ?
Offline Latole
« Reply #20 on: February 20, 2022, 03:42:23 am »
Randall LB103 ;
The power transformer seems to be underpowered. The voltage of the filaments without any EL34 tubes is 6.48 volts AC.
With the tubes, it drop to 5.65 volts AC
Amp made in China ........
Offline uki
    • Uki's Guitar Trip
« Reply #21 on: February 20, 2022, 06:43:57 am »
Yay...  :sleepy2:
There are still things to be noted there, I'm sure it isn't all that bad, is it ?
Offline Latole
« Reply #22 on: February 20, 2022, 07:33:00 am »
Yay...  :sleepy2:
Until it work , this amp may not worth to spend money for repair in 10 years
It go two times at a big service center with no success; repair do not last,
What thy do ? I don't know, I see not work on circuit and customer don't know
« Last Edit: February 20, 2022, 07:36:10 am by Latole »
Offline uki
    • Uki's Guitar Trip
« Reply #23 on: February 20, 2022, 08:32:47 am »
customer don't know
I usually tell everything to the customer, what they should know, after all the item belongs to them, and it creates trust, explore in though all possibilities, list some options, include cost and benefit, tell the customer.
What thy do ?
That is a good question! If repairing is a no go, then salvage, reuse the cab, chassis, working parts, repurpose, build something durable and dependable. Get rid of the cheese cheap chingling disposable stuff !! I would !! If the fee is right !
« Reply #24 on: February 20, 2022, 08:33:00 am »
.... maybe it was the case for this Squier 10 ?
I really think that the amp is only labeled Fender but is build in China and bought there (by Fender that resells), like your Randall (?)
« Last Edit: February 20, 2022, 08:35:34 am by kagliostro »
Offline Latole
« Reply #25 on: February 20, 2022, 10:09:42 am »
customer don't know
That is what I do too. And with pictures.
Many service big box don't tell, too many people between customer and tech ? . Or  ( and ) the customer don't remember ?
