September 08, 2026, 03:49:18 pm
Hoffman Amps Forum image Author Topic: Fat Switch + More Gain  (Read 6122 times)
Offline Geezer
« on: June 18, 2005, 05:44:17 am »
        > Fat Switch + More Gain
<< Prev Topic | Next Topic >>
Author  Comment
LooseChange
Senior tube assistant
(3/27/04 11:07 am)
 I installed a "FAT" switch. Standard arrangement: Switching a 22uf cathode bypass across the existing 3.3k/.1uf bias on half of a 12AX7. I have a 100k across the switch. It works perfectly.
BUT, I want to add more gain: I added a 1.5K in parallel with the 22uf. Problem is I get a bump noise every time I switch it in or out.
Got any ideas to stop the bump noise??
Thanks!!
PHATamps
I only work on tube amps
(3/27/04 11:25 am)
 Re: Fat Switch + More Gain
 That's a pretty radical bias shift. With the added resistor you're going from 3.3K to about 1K. If you want wind up with the standard 1.5K/22uF, replace the 1.5K you added with a 2.7K. This ought to reduce the bump you're hearing, but may not eliminate it.
LooseChange
(3/27/04 3:21 pm)
 Actually, I tried a 3.3k and a 2.2k. The bump was still there. So I figured I'd go for over the top.
I guess there is NOT a scheme to get that "bump" out of there??
 Topic Commands
Powered By ezboard® Ver. 7.32
