August 01, 2026, 10:47:00 am
Hoffman Amps Forum image Author Topic: Very stable 9VDC supply  (Read 12430 times)
Offline Colas LeGrippa
  • MAKE LOVE NOT WAR
« on: February 25, 2022, 01:54:12 pm »
Hola amigos, over the last weeks, I had time to experiment with power  supplies, I destroyed some builds I made, I kept some.
A couple of years ago, I had bought a dozen of 16VAC  transformers and I wanted to use them in some kind of project. I found out that the most stable power supply for pedals was the one shown in the picture. It yields 9.4 V - 9.7V at 1 A and the three pedals that I connected to it did not lower its voltage. The schem. does't use a LM 7809 but rather a TIP 41transistor.
P.S.: call me Alvin.
Offline Latole
Re: Very stable 9VDC supply
« Reply #1 on: February 27, 2022, 03:29:46 am »
Offline Latole
« Reply #2 on: February 27, 2022, 03:34:03 am »
« Reply #3 on: February 27, 2022, 05:38:23 am »
Here's my 9V pedal board supply. Good for 3 amps. Currently powering 9 pedals without breaking a sweat.
  • MAKE LOVE NOT WAR
« Reply #4 on: March 01, 2022, 01:46:48 pm »
Interesting. I don t know that 123K transistor
  • MAKE LOVE NOT WAR
« Reply #5 on: March 01, 2022, 01:49:04 pm »
Latole, c est bennn trop cher j ai tout ce qui faut ici pour les fabriquer
« Reply #6 on: March 01, 2022, 02:07:30 pm »
The LM123K is a 5V 3A regulator chip in a TO-3 case.
Offline Latole
« Reply #7 on: March 01, 2022, 02:40:05 pm »
J'en ai eu quelques uns gratis.........
You are right, it is less expensive if you build yourself
  • MAKE LOVE NOT WAR
« Reply #8 on: March 01, 2022, 03:05:04 pm »
Hey Steve, I don t get that one. 5V regulator yielding 9 V ?
« Reply #9 on: March 01, 2022, 05:46:32 pm »
Do you see the extra resistors?
However it appears the LM123 (any flavor) is out of production?
« Reply #10 on: March 02, 2022, 08:41:32 am »
Easy. That regulator puts out 5V in respect to the "Reference" pin. If the reference pin is connected to ground, you get 5V out. But if you put 1.3V on the reference pin, the output becomes 5V + 1.3V = 6.3V. Or, if you put 4V on the reference pin, the output becomes 9V. Or, if you use a voltage divider on the output, as I did, and you put a pot in the voltage divider, you can adjust the output voltage to what you want, within reason. In all cases, the voltage between the output and reference pins will always be 5V, but the voltage between the output pin and ground will be the sum of 5V plus whatever voltage is on the reference pin.
The simple zener/BJT series pass voltage regulator you have has been around since the dawn of transistors. It works very well but lacks any overload protection. Short the output to ground (touch the positive and negative leads together) and you will kill the transistor and possibly damage the rectifier and transformer. This short can also occur due to a shorted filter cap inside one of your pedals. My LM123K and the 7809 have overload protection built in and will gracefully shut down if an overload occurs, thus preventing any damage to itself or any other upstream components. When the overload condition is removed, the regulator will happily come back to life.
Sometimes simple is not better.
  • MAKE LOVE NOT WAR
« Reply #11 on: March 03, 2022, 10:36:06 am »
Impressed.
Thanx for your extended explanation. You 'll send me a bill for the electronic lesson :worthy1:
PRR, sure I had seen the resistors but I wasn't sure if they were part of a voltage doubler circuit or what. My knowledge of electronic theory is quite limited you know. I know how to build good sounding tube amps though.
Regards
