September 15, 2026, 04:18:49 am
Hoffman Amps Forum image Author Topic: UberGain PowerSupply  (Read 4925 times)
Offline MiniVanMan
« on: February 27, 2022, 06:52:35 pm »
Interested in doing an UberGain from over on AX84.
I'm looking at the power supply drawing and in the comments it suggest film capacitors for C2, C4, C5, C6
https://ax84.com/archive/ax84.com/static/ubergain/AX84_UberSEL_091224.pdf
I'd like to make this as compact as possible and utilize a cap can.  I know the debate between electrolytic and film on a power supply is an old one, but since it was mentioned specifically I thought I'd ask.  I don't like deviating from a design and design notes, but the size difference is significant between four 10uF 400+V Film Caps and four 10uF, 450V electrolytics in a cap can.
Is there something in the design that would really favor the film caps?
Re: UberGain PowerSupply
« Reply #1 on: February 27, 2022, 08:14:47 pm »
If you use electros, the internet will despise you, you will be blocked from MySpace, your children will disinherit you, and your guitar will only play Polka. (If indeed you like polka, your axe will be stuck in Whoopy Kat mode.)
Offline MiniVanMan
« Reply #2 on: February 27, 2022, 08:36:01 pm »
As it turns out this is going to be a dedicated polka amp.  Gonna run an accordion through it.  It might see some bagpipe action as well.
As for my kids disinheriting me?  I could only hope.
And I was blocked from MySpace a long time ago when I refused to acknowledge the superior sonic capability of Monster speaker cable.
« Reply #3 on: February 27, 2022, 09:38:34 pm »
I see Jimmy Sturr weekly, and I would use electros.
