September 19, 2026, 05:05:25 pm
Hoffman Amps Forum image Author Topic: Build suggestions for a W02273 PT  (Read 4938 times)
Offline 72Blazer
  • Long live rock!
« on: March 05, 2022, 01:08:16 pm »
I scored a pair of W022723 PTs a while back and I'm interested in hearing from the pros what a good amp choice would be.  Looking for suggestions as well as these 2 questions:
Could I build a Stout?
Could I build a beefier Princeton Reverb?
What other amps come to mine?
Thanks!
Re: Build suggestions for a W02273 PT
« Reply #1 on: March 05, 2022, 01:38:15 pm »
That should work fine with a 2x6L6 amp.
Offline ac427v
« Reply #2 on: March 06, 2022, 07:13:28 am »
Yup. Weber says it's for a Vibrolux Reverb 35 watts. Using it for something smaller will pull less current than it wants and voltages will be too high. A 5U4 rectifier may help reduce the B+ voltage but heater voltage could be an irksome problem to jury rig a "fix."
« Reply #3 on: March 06, 2022, 11:15:17 am »
^What Sluckey said^
(This would work for a tweed Bassman 5F6a)
Offline Lectroid
« Reply #4 on: March 17, 2022, 01:45:16 pm »
72,
Check out this thread: https://el34world.com/Forum/index.php?topic=28707.0
It's another possibility for that 200mA PT.
Magis bos clocca!
Free Beer Tomorrow!
Offline 72Blazer
  • Long live rock!
« Reply #5 on: March 17, 2022, 07:39:17 pm »
I did-thanks!  Curious if the tranny he used has same chassis dimensions bolt/cutout requirements as mine. he used the Hammond P-T290CX. Mine is a Weber W02273.
Offline Dyerseve726
« Reply #6 on: March 18, 2022, 12:16:23 am »
The 290CX is HUGE. The bell end fits perfectly in the Weber 6a14 chassis, but I do have to drill new bolt holes. It nearly touches the can cap though. Better than trying to widen a square hole. Here are the dimensions (pdf attached) if you'd like to compare it with the one you have. The cutout on the Weber chassis is 2.75x2.23". And I obviously love the 6l6 Princeton I built with a very similar PT, so that's what I say you should make!
« Last Edit: March 18, 2022, 12:30:43 am by Dyerseve726 »
