September 16, 2026, 02:56:54 pm
Hoffman Amps Forum image Author Topic: Kalamazoo 2 tremolo intensity  (Read 5649 times)
Offline isaac_teller
« on: March 09, 2022, 01:37:23 am »
Hello. I've built a clone of the Kalamazoo 2. Works great, sounds great. However there is no intensity control. What would I need to do to increase the intensity without adding a knob(fixed intensity level). Thank you.
https://schematicheaven.net/bargainbin/kalamazoo_m2s.pdf
Re: Kalamazoo 2 tremolo intensity
« Reply #1 on: March 09, 2022, 05:05:57 am »
There may not be any very simple mod because your circuit is already delivering all the tremolo it can. You can try replacing R5 and C13 with a red LED. This will definitely make the tremolo stronger but may not work in your circuit. Easy to try.
You have a spare triode. Look at some circuits like the Supro 6622. You can set the strength of the tremolo by changing the value of the 220K grid resistor for V4-7.
« Reply #2 on: March 09, 2022, 10:59:12 am »
What about increasing the plate resistor to 220k (to get more gain)?
« Reply #3 on: March 09, 2022, 11:08:34 am »
That sounds like a good idea. I'll try it.
« Reply #4 on: March 09, 2022, 03:20:38 pm »
I doubt "increasing gain" will get you there.
Is this really using 1-1/2 12AX7s?? What could you do with the odd triode? Seems like Fender had some buffered trem drive.
« Reply #5 on: March 09, 2022, 05:04:43 pm »
good call, I looked n checked the box that both 1/2's were used, missed that 1st tube  :laugh:
« Reply #6 on: March 10, 2022, 12:43:12 am »
The version I built used a 6AV6 for the tremolo. There's no unused triode. I lowered V1A cathode resistor to 1K5. It sounds better to my ears.
« Last Edit: March 10, 2022, 12:47:24 am by isaac_teller »
« Reply #7 on: March 10, 2022, 04:47:49 am »
That kind of info should have been included in your first post.
