September 17, 2026, 11:53:03 pm
Hoffman Amps Forum image Author Topic: Hoffman princeton reverb, tremelo speed  (Read 6098 times)
Offline Stuff4bikes
« on: March 11, 2022, 12:10:14 am »
Tremelo speed is way to fast. 1 on mine is like 10 on a normal circuit, half way is like a machine gun.
I tried the .02 on the middle and first cap separately and it just kills the tremelo completely.
Also I think my new blackface style footswitch is faulty...
Online tubeswell
Re: Hoffman princeton reverb, tremelo speed
« Reply #1 on: March 11, 2022, 12:50:11 am »
Somewhere between 0.02uF and 0.03uF on the first C/R filter should slow the trem down
Offline ac427v
« Reply #2 on: March 11, 2022, 07:10:53 am »
Check to verify that the Speed pot value is 3 meg ohms Reverse Audio (3MRA).
Offline Stuff4bikes
« Reply #3 on: March 11, 2022, 08:12:32 pm »
Definitely the correct pot....straight off the AES website.
« Reply #4 on: March 11, 2022, 08:23:10 pm »
Your footswitch is not a factor. You don't need it for reverb or tremolo to work. So, unplug it until your issue is resolved.
Try a different 12AX7. Measure voltages on the trem tube. Post some hi-rez pics. Compare your wiring and component values to the layout.
Offline Stuff4bikes
« Reply #5 on: March 11, 2022, 08:32:51 pm »
I have been doing all that to no avail......deep down inside I know you are right though...I will get some voltage specs for you.....I am not good at pictures.
V4.......1-250.   2-0.   3-2.24.  6-200.  7-20.  8-60.
« Last Edit: March 11, 2022, 08:44:42 pm by Stuff4bikes »
« Reply #6 on: March 11, 2022, 08:47:05 pm »
Hoffman's PR is a proven design. You will most likely find that your amp ain't wired just like his layout, or you have used a wrong value component somewhere, or your solder skills and workmanship are lacking. On a rare occasion you will find a faulty new component. Hi-rez pics are very helpful in solving new build issues. Not much left to say if we can't see the amp. Kinda like throwing darts in the dark.
Offline Stuff4bikes
« Reply #7 on: March 11, 2022, 08:48:36 pm »
Did you see the numbers I posted.
« Reply #8 on: March 11, 2022, 08:51:01 pm »
Voltages do not look suspect.
Offline Stuff4bikes
« Reply #9 on: March 11, 2022, 08:53:22 pm »
Dang it.....was hoping that was it.........what resistors should I look at for value verification.....
I will get some pics when the sun comes out tomorrow.....
« Reply #10 on: March 11, 2022, 09:16:04 pm »
Check all components in this pic. Verify proper values and that they are connected according to the layout.
