September 18, 2026, 01:56:51 pm
Hoffman Amps Forum image Author Topic: Marshall Haze 40 Intermittent Volume Drop  (Read 6477 times)
Offline Travis8
« on: March 15, 2022, 06:10:46 pm »
Hi!
My Haze 40 have an intermittent volume drop, I check tubes and they work fine.
Some recommendation?
Thanks!!
Offline uki
  • Hot Tube Hot Sound
    • Uki's Guitar Trip
Re: Marshall Haze 40 Intermittent Volume Drop
« Reply #1 on: March 15, 2022, 06:41:19 pm »
Some more info about the amp is helpful, like: schematic, voltage readings, some high resolution pics too.
https://soundcloud.com/ukiuki
Offline Latole
« Reply #2 on: March 16, 2022, 04:42:34 am »
Bad solder or bad contact in power supply. Check all connectors
Input jack broken solder; shake the guitar cable and what happen with sound .
Bad contacts on Send / return 1/4 jack ;  Plug patch cable, it will bypass contacts it they are bad
Tubes can't be an issue; they always work or never work, never on and off
Schematic :
https://www.thetubestore.com/lib/thetubestore/schematics/Marshall/Marshall-Haze-MHZ40C-Schematic.pdf
Owner manual :
https://www.fullcompass.com/common/files/12328-MarshallHazeSeriesManual.pdf
« Last Edit: March 16, 2022, 04:45:10 am by Latole »
Offline Latole
« Reply #3 on: March 16, 2022, 04:49:22 am »
Offline Latole
« Reply #4 on: March 16, 2022, 04:54:36 am »
Marshall Haze 40 Guitar Amp repair
Attempting to fix the Marshall Haze 40 Guitar amp
Has sound distortion issues. It plays fine for 10 minutes, but then gets really quiet and sounds horrible
Offline Travis8
« Reply #5 on: March 16, 2022, 05:23:43 am »
Schematic :
Owner manual :
I know hot rods have same issues, maybe R14 or/and R15 are bad? I will check all the power supply components
Offline Latole
« Reply #6 on: March 16, 2022, 05:30:11 am »
A similar sound problem does not mean that it comes from the same parts. That would be too easy.
Different causes can cause the same problems; the sound on and off.
There are dozens of possibilities.
Start by checking the easiest part ; Input jack, Send and Return
Offline Latole
« Reply #7 on: March 16, 2022, 05:35:17 am »
R14, R15 in the HR or in the Marshall ?
It can't be those on the Marshall, these are center tap heater resistors
Offline Travis8
« Reply #8 on: March 16, 2022, 09:34:23 am »
Maybe this cap is bad?
Its like its work fine but sometimes volumes drop.
Offline Travis8
« Reply #9 on: March 16, 2022, 09:45:01 am »
C17, C67, C31, C49, C15, C69 looks like the photo
Offline Latole
« Reply #10 on: March 16, 2022, 10:03:52 am »
Bring amp to a qualified amp tech
