September 18, 2026, 12:53:26 pm
Hoffman Amps Forum image Author Topic: Bias supply resistor question.  (Read 3816 times)
Offline joesatch
  • save me from myself.
« on: March 15, 2022, 10:48:06 pm »
re-purposing a PT from a Hot Rod Deluxe. The bias tap is like 42VAC. In the schematic it runs straight to the reversed diode with no resistor in series. On most AB763 i see a 470ohm 2 watt resistor in series. What is this resistor for and do i need it?
« Last Edit: March 15, 2022, 11:00:57 pm by joesatch »
Re: Bias supply resistor question.
« Reply #1 on: March 16, 2022, 02:54:15 am »
Most AB763 PTs have a 50VAC bias tap. The 470Ω drops a little voltage. It also provides some protection to the PT in case the diode and/or bias cap short.
Since your bias tap is only 42V I suggest building the bias supply like the HRD. It has better filtering.
