September 17, 2026, 09:17:30 pm
Hoffman Amps Forum image Author Topic: Sound city 120 h.t. Fuse blown  (Read 9872 times)
Offline mattiambro
« on: March 30, 2022, 11:29:27 am »
Hi,there I have in my hands a sound city 120 Mark IV that blows H.T. fuse even with no tubes. Rectifier seems to be ok, I tried it with no load gives a good Voltage.
Then I add the 200uF caps section and it was still good. Adding all the rest it blows. I did not find any shorted Cap and checked some resitors alomg tracks and seems ok.
I Know these amps are campus for being noisey but this one does a pretty consistent noise even without tubes and it increase with current Using a variac but at a certain Level it blows variac fuse that is 2Amp, main fuse of the amp is 3Amp. Anyone have suggestions? Thanks to everyone
Re: Sound city 120 h.t. Fuse blown
« Reply #1 on: March 30, 2022, 04:35:04 pm »
Has to be rectifier, mains caps, or wiring. Focus there.
« Reply #2 on: March 30, 2022, 07:07:02 pm »
With the amp off and discharged, use your R meter to measure between the HT supply nodes (at each filter cap) and the ground return. Looking for low or no resistance. (It might not be a shorted cap (or it still might be) but it could be a short between the filter cap/resistor connection point and the ground return
Or using a dimmer or variac, measure the voltages at each HT supply node (after the reservoir cap), looking for the node that is reading 0V
Offline Latole
« Reply #3 on: March 31, 2022, 04:25:57 am »
To work in a amp wich blow fuse, a lamp current limiter is often a must.
« Reply #4 on: March 31, 2022, 04:26:26 am »
A light bulb limiter with a suitable bulb wattage can be very handy in  helping to track down the root cause.
Offline mattiambro
« Reply #5 on: March 31, 2022, 02:46:16 pm »
The only node where I have small resistance,(30ohm) it is the first node in series of the rectifier, and also all along rectifiers except where transformer windings are connected. Does not seems so right  :w2: :worthy1:
« Reply #6 on: March 31, 2022, 03:41:49 pm »
A schematic helps.  The 1st two filter cap nodes are stacked, so the chances of both caps shorting on each of these nodes is 1 in 4. Also, the 220k balancing resistors will reduce the likelihood of a fuse blowing if one of these cap segments is shorted. You infer that the fuse holds with the std-by switch off. So we can assume the reservoir cap node and the rectifier is working. (What VDC do you get there?).  The supply resistors are where the brunt of any major voltage drop will be evident. How does the 100R look? What about the 6k8? the 22k? If one of these looks burnt, lift the following cap out of the circuit and look at the idle voltages
Offline mattiambro
« Reply #7 on: March 31, 2022, 06:29:19 pm »
Resistors seems fine and their values are fine . I checked wiring and seems fine, I will give anotuer shot as sono ad I can. With stand-by off I see +450V at rectifier output. With stand-by on It Is below the variac output.
« Reply #8 on: March 31, 2022, 07:20:51 pm »
...With stand-by off I see +450V at rectifier output. With stand-by on It Is below the variac output.
So, what are these voltages (at each filter cap/HT supply node)?
Offline Williamblake
« Reply #9 on: April 01, 2022, 12:50:36 am »
Also the screen grid resitors in those amps can come very close to the chassis.
Offline mattiambro
« Reply #10 on: April 01, 2022, 10:21:55 am »
Almost every node after standby has same voltages (150v input 80v at nodes) with the stand by switch on. Resistor in series of the fuse was really hot. Now I'll try rewiring that section and are what happen, I guess..  :dontknow: screen grid resistor does not contact chassis but thanks for the suggestion
Edit: I have disconnected the first resistor (100r) after standby switch so that only center tap of O.T. Is connected and I already have bad voltages
« Last Edit: April 01, 2022, 10:42:10 am by mattiambro »
« Reply #11 on: April 01, 2022, 11:19:23 am »
Reconnect the 100R resistor but lift the 32uF cap
Offline mattiambro
« Reply #12 on: April 01, 2022, 11:42:36 am »
Same results
« Reply #13 on: April 01, 2022, 11:54:19 am »
Okay so lift the screen supply cap ground node. What happens?
Offline mattiambro
« Reply #14 on: April 03, 2022, 09:23:47 am »
Same results. I see only few ohms of resistance from plates to Ground and from center tap to Ground that isn't good right? Output transformer is Hammond 1960t
« Reply #15 on: April 03, 2022, 10:21:45 am »
Disconnect both OT plate leads from the tube sockets. Do you still have low resistance from socket pin 3 to ground?
Offline mattiambro
« Reply #16 on: April 05, 2022, 10:40:10 am »
Nope
So Bad O.T. ???
« Reply #17 on: April 05, 2022, 10:44:39 am »
OK, now disconnect the OT primary center tap lead from the B+. Do you measure low resistance from the primary CT lead to ground?
Offline mattiambro
« Reply #18 on: April 05, 2022, 10:52:16 am »
Yup
« Reply #19 on: April 05, 2022, 11:02:23 am »
I would call it dead.
Offline mattiambro
« Reply #20 on: April 05, 2022, 12:09:34 pm »
 :BangHead: :cussing:
Offline IndustryCode783401
« Reply #21 on: April 08, 2022, 04:46:39 pm »
I'd suggest replacing all 4 diodes in the HT power supply. You could use an ohmmeter to test these to see if one is not like the others, but if you replace one then replace all four.
