July 30, 2026, 09:16:09 am
Hoffman Amps Forum image Author Topic: I'm getting a light shock  (Read 8755 times)
Offline pbman1953
« on: April 02, 2022, 09:33:32 am »
I finished my Fender Super Twin Bass amp project. I installed the chassis in a Mojotone Fender-like cab. There are 2 metal strips on the top of the cab. The bolts go through the cab top and chassis to tighten with a nut.
If I happen to touch the metal strips while changing the metal speaker cab jack, I get a light shock.
Does anyone know why? Is this normal ?
Offline 72Blazer
  • Long live rock!
Re: I'm getting a light shock
« Reply #1 on: April 02, 2022, 09:55:45 am »
I'm still new but we'll definitely need detailed pics of the guts of the guts inside the chassis as well as the schematic/layout used.  Any special mods you installed?  Death cap? etc..
Someone will be able to assist though.
Vr
J.
Offline acheld
« Reply #2 on: April 02, 2022, 10:04:53 am »
If your chassis has a permanent and dedicated connection to earth, that should not be happening.
Is your chassis grounded?
Is your wall outlet properly wired?   You'd be surprised how often it is not . . . I always carry an outlet tester (one like this   https://www.amazon.com/Receptacle-Tester-Klein-Tools-RT110/dp/B01AKX3AYE/ref=sr_1_7?crid=JOFASABWQ4Z7&keywords=outlet+tester+plug&qid=1648911707&sprefix=outlet+tester%2Caps%2C137&sr=8-7
Check these two items first.
« Reply #3 on: April 02, 2022, 10:06:33 am »
Fender Super Twin
new build or brought back to life?
if original, was it a 2 prone'r?
« Reply #4 on: April 02, 2022, 10:49:23 am »
It's magic. But simple solution... Don't do that!
Read this short thread about a very similar situation...
     https://el34world.com/Forum/index.php?topic=28634.msg315352#msg315352
Offline pbman1953
« Reply #5 on: April 02, 2022, 12:57:25 pm »
3 prong plug with the green wire screwed and soldered to the chassis
The PT  ground and the OT grounds are grounded together.
 The death cap was removed before I got it
« Reply #6 on: April 02, 2022, 01:40:06 pm »
Picture please.
Offline pbman1953
« Reply #7 on: April 02, 2022, 02:16:19 pm »
3 prong green ground
Offline pbman1953
« Reply #8 on: April 02, 2022, 02:17:05 pm »
PT black wire ground
« Last Edit: April 02, 2022, 02:19:55 pm by pbman1953 »
Offline pbman1953
« Reply #9 on: April 02, 2022, 02:19:14 pm »
OT Ground.
From the PT wire ground picture, there's a black wire coming to the EXT speaker jack. Then from there, a black wire goes over to the Spk jack , where the OT connects
« Reply #10 on: April 02, 2022, 02:33:14 pm »
I wouldn’t trust that mains ground connection. Looks old and it may be failing. Install a new mains cord with a new safety ground. Clamp the bare wire strands securely and firmly to a ring terminal before soldering. Then bolt the ring terminal securely to the chassis with it’s own dedicated bolt and locking nut. (Make sure the chassis is clean before attaching the bolt.)
Also make sure your speaker Jack sleeve is wired to the OT secondary common.
« Last Edit: April 02, 2022, 02:35:59 pm by tubeswell »
« Reply #11 on: April 02, 2022, 02:44:27 pm »
How??? The strips bond to the chassis their screws. The speaker plug is in the jack which is firmly screwed to the chassis. The chassis is a heavy hunk of metal. The strips and plug "can't" be at different voltages.
Something you are not telling us. Crappy connections. Standing on dirt or concrete. Silk undershorts in dry-dry weather.
Offline pbman1953
« Reply #12 on: April 02, 2022, 03:06:00 pm »
Ok,
I'll buy a new wire. I have ring terminals, thanks
Offline pbman1953
« Reply #13 on: April 02, 2022, 03:06:58 pm »
Here are the strips. Think of a Bassman and other early 60's Fenders.
Offline pbman1953
« Reply #14 on: April 02, 2022, 03:17:28 pm »
When you say secondary common, please explain. From there's the power wires Red, Brown & Blue, white/brown & white/ blue, then the speaker wires- black and green. There's only one set of speaker wires because the OT only has a 4 ohm out put
Offline pbman1953
« Reply #15 on: April 02, 2022, 03:19:22 pm »
The black speaker ground wire goes to the speaker jack and it's using the chassis as it's ground from the compression to the chassis.
« Reply #16 on: April 02, 2022, 03:26:06 pm »
Please explain exactly what this means.
Offline pbman1953
« Reply #17 on: April 02, 2022, 03:58:46 pm »
Meant to say while touching
« Reply #18 on: April 02, 2022, 03:59:35 pm »
In that case, the end of the secondary which is not the end with the NFB loop attached.
« Reply #19 on: April 02, 2022, 04:40:13 pm »
Still unclear.
Is the "metal speaker cab jack" on the separate speaker cab box? If so, maybe you have the wires reversed in your speaker cable. IE, the OT ungrounded "hot" lead is actually connected to the sleeve of the speaker cab jack. Make sure your speaker cable plugs are wired tip to tip and sleeve to sleeve.
Offline pbman1953
« Reply #20 on: April 02, 2022, 06:31:14 pm »
I have 2 heads , one on top of the other. I switch the cab back and forth between the 2 heads. Individually.
The cab's speaker wire has  a metal, Switchcraft, cover. The amp's stock jack is some kind of shorting plug. After a review you all sent me I decided, since I ordered a new OT with 4 and 8 ohm outputs, that I'd remove the the shorting jack and install a standard 1/4" non- shorting jack.
I sent a picture of the stock jack and next to it the jack I replaced it with. Why do they use a grounding jack?
After installing the standard jack he issue seems to have been cured. I can touch both the chassis and the speaker jack while it's plugged into the speaker cab
« Last Edit: April 03, 2022, 07:30:07 am by pbman1953 »
« Reply #21 on: April 03, 2022, 10:44:21 am »
The grounding jack puts a ground on the OT hot lead only when nothing is plugged into the speaker jack. This will protect the amp. It's much better to have a short on the OT secondary than an open circuit.
Offline pbman1953
« Reply #22 on: April 04, 2022, 04:17:24 pm »
That seems confusing. Wouldn't that be a direct short?
Next question-
I'll be receiving soon an OT with 4 & 8 ohm out puts.  There are 2 holes and I can use one  for each ohm value. Should I install new jacks with shorting plugs?
or
one shorting jack with an ohm selector  toggle ?
« Reply #23 on: April 04, 2022, 04:25:24 pm »
Yes  as Sluckey said it protects the OT from harm caused by flyback voltage that would occur if it was open, not shorted with nothing plugged in.
Next question-
or
The answer to that should be obvious.   If you want to select between two different impedance taps of an OT you should use an impedance switch.
« Last Edit: April 04, 2022, 04:27:53 pm by mresistor »
« Reply #24 on: April 04, 2022, 05:15:59 pm »
Do this.
Offline pbman1953
« Reply #25 on: April 04, 2022, 05:21:32 pm »
Cool, that's how I have it on my Traynor
« Reply #26 on: April 04, 2022, 10:02:13 pm »
On smaller tube amps, particularly self-biased, shorting the output is safe. The power intake does not change (much) with load, and the idle condition is the hottest possible condition. On The Other Hand, an open un-loaded output and any signal risks voltage kick-up in the OT, which will eventually puncture the insulation.
Transistor amps are mostly different because they will suck more power "as needed", or when shorted.
However, is this the SIX 6L6 amplifier? It is likely to aim at transistor design thinking for most power. The best thing is to NEVER mis-load it.
