September 17, 2026, 11:52:49 am
Hoffman Amps Forum image Author Topic: Late 60's 50W Marshall Bridge Rectifier Specs  (Read 5029 times)
Offline pgussler
  • Once bitten, twice shy....
« on: April 02, 2022, 05:15:17 pm »
Does anyone have the specs for the bridge rectifier found on a late 60's Marshall 50W Lead.  Part number is IIR GB256/PA 70 21.  Thanks in advance.
Paul G.
Offline pgussler
Re: Late 60's 50W Marshall Bridge Rectifier Specs
« Reply #1 on: April 02, 2022, 05:37:32 pm »
Never mind - found it.   1000v 25A
Paul G.
« Reply #2 on: April 02, 2022, 05:42:44 pm »
25A seems mighty generous, especially for late 1960s.
I absolutely approve of greatly over-speccing rectifiers. I used to get paid salary to replace marginal rects but that job is gone. Meanwhile the costs (labor and headache) of replacing will cover a heap of over-speccing so you never have to replace it.
Just be sure it can be made to fit.
Offline pgussler
« Reply #3 on: April 03, 2022, 04:06:04 am »
Agree on the amperage generosity and also on the overbuilt approach.  The failed unit is a big sucker to begin with and the dimensional specs from the data sheet for the replacement part indicates it will plop down right in its place.  Thanks for the reply.
Paul G.
Online pdf64
« Reply #4 on: April 03, 2022, 04:32:25 am »
1kV is marginal.
Perhaps that’s why the original failed?
Bear in mind only 2 of the 4 diodes in the FWB package are in circuit.
My take is that even just 2 series pairs of 1N4007 would be better.
Offline pgussler
« Reply #5 on: April 06, 2022, 04:56:09 am »
Thanks for the follow up.  All points well taken.
Paul G.
Online pdf64
« Reply #6 on: April 09, 2022, 06:09:36 pm »
Here’s report of 1kV diodes failing https://ampgarage.com/forum/viewtopic.php?f=9&t=35385
