September 17, 2026, 09:43:19 am
Hoffman Amps Forum image Author Topic: Bugera V22 power transformer specs  (Read 5696 times)
Offline mk_716
« on: April 05, 2022, 08:55:18 pm »
Hello all,
   I've got a donor V22 that I'd like to use the iron from this amp (the amp is board is beyond repair).
   I'm especially interested in the heater current, looks like V1, V2 and V3 heaters are all on a 15V DC and just the power tubes are using the 6.3V.
   Makes me suspicious there isn't much current there.
   Does anyone know?   I've been searching and I can't find it on the webs.
Thanks in advance,
mike
Re: Bugera V22 power transformer specs
« Reply #1 on: April 05, 2022, 09:35:19 pm »
Now, they are clearly on +/-18V.
Why can't you do it the same way? Do you need more than three small bottles?
« Reply #2 on: April 05, 2022, 10:08:59 pm »
Hello all,
  ... heater current, looks like V1, V2 and V3 heaters are all on a 15V DC and just the power tubes are using the 6.3V.
What PRR said - its from the +/-25VDC supply dropping to +/- 18VDC via the 47Rs. Total current draw is 150mA for this part of the circuit
Offline mk_716
« Reply #3 on: April 05, 2022, 10:20:14 pm »
Hey guys,  yes 18v sorry.
  What I'd like to do is sluckey's AC-15,  lots more bottles.  I want to think using  a similar method I could squeeze out enough,  but I'm just not sure.  (Just under 4 for that)  feels like I'm pushing my luck.
  Sluckey's Dual-Lite is my plan b which is probably a more sensible choice with what I've got...
Mike
« Reply #4 on: April 05, 2022, 11:05:47 pm »
Might be less stressful to use a more appropriate PT.
« Reply #5 on: April 05, 2022, 11:16:08 pm »
Remember that voltage in series adds up, but the same current 'flows' through all components in series. 50VDC (+/- 25VDC) is borderline for 4 x 12AX7 filaments in series @ 150mA (4 x 12.6 = 50.4) as you wouldn't have room for any limiting resistors to deal with startup surge. (Resistance is lower at colder temperature, so you'll get a spike in voltage at startup until the heaters warm up, which is not good for a maxed out +/- VDC power supply without any limiting resistance in series.)
Offline mk_716
« Reply #6 on: April 06, 2022, 12:26:42 pm »
Thanks guys,
m.
