September 16, 2026, 07:27:15 pm
Hoffman Amps Forum image Author Topic: Old Pro Junior Weird Noise  (Read 11912 times)
Offline Travis8
« on: April 06, 2022, 02:48:21 pm »
Hi
My old Pro Junior have a weird Noise, like an ugly distorted sound on every volume.
I check the circuit, changue filter caps (one was out of Range) and try new valves and the problem still there.
Also I replace C13, C14, C11 and C10.
Some ideas or Help?
Thanks...
Offline Travis8
Re: Old Pro Junior Weird Noise
« Reply #1 on: April 06, 2022, 02:50:10 pm »
« Reply #2 on: April 06, 2022, 04:11:41 pm »
Are there any voltages in there?
Offline Travis8
« Reply #3 on: April 06, 2022, 05:02:30 pm »
All caps have good voltages
« Reply #4 on: April 06, 2022, 06:14:35 pm »
And these would be??
« Reply #5 on: April 06, 2022, 06:59:27 pm »
I was thinking the tubes. Does V13 G2 have 111 Volts, or whatever the service data says? If any of the readings is way-wrong, that is a CLUE.
Offline Travis8
« Reply #6 on: April 07, 2022, 08:59:50 am »
Preamp tubes:
V1:
9- 3.3v
5- 3.3v
4- 3.3v
V2:
9- 3.3v
5- 3.3v
4- 3.3v
« Reply #7 on: April 07, 2022, 12:48:52 pm »
Offline Travis8
« Reply #8 on: April 08, 2022, 04:04:54 am »
TP4 : 1.9VDC
TP2 : 122VDC
TP6 : 125VDC
TP8 : 1.8VDC
TP15 : 27.7VDC
TP12 : 176.9VDC
TP10 : 177VDC
« Reply #9 on: April 08, 2022, 04:27:34 am »
Those look okay
What about the idle voltages on the output tubes' grids, screens and plates? (and do any of the screen grid resistors measure open?)
Offline Travis8
« Reply #10 on: April 08, 2022, 04:36:31 am »
I look at + lug on c13 and c14 and I get 0 volts.
let me see screen grid resistors
Online sluckey
« Reply #11 on: April 08, 2022, 06:54:13 am »
That's right. But what do you measure on the negative lug of those caps?
Offline Travis8
« Reply #12 on: April 08, 2022, 09:52:47 am »
Those look okay
Plate: around 350vdc bouth valves
Screen grid: 322,8vdc bouth valves
Control grid (TP13 and TP14): v4: 0,8vac  v3: 0,8vac
« Last Edit: April 08, 2022, 10:04:30 am by RCZ »
Offline Travis8
« Reply #13 on: April 08, 2022, 09:55:12 am »
r20 and r23 are ok, 1,5kohm
Offline Travis8
« Reply #14 on: April 08, 2022, 09:59:16 am »
TP23: 12,8vdc
Offline Travis8
« Reply #15 on: April 08, 2022, 10:02:33 am »
TP2 : 122VDC
TP4 : 1.9VDC
TP6 : 125VDC
TP8 : 1.8VDC
TP10 : 177VDC
TP12 : 176.9VDC
TP15 : 27.7VDC
TP23: 12.8VDC
TP13: 0.8VAC
TP14: 0.8VAC
Online sluckey
« Reply #16 on: April 08, 2022, 10:26:30 am »
TP23 should be a negative DC voltage. TP13 and TP14 should also be a negative DC voltage and should be about the same as TP23. Please check these three points again.
Any AC voltage you see at those test points are meaningless unless you have injected the proper test signal into the input jack. We don't need those at this time.
Offline Travis8
« Reply #17 on: April 08, 2022, 10:59:43 am »
Yes.
TP23: -12.8VDC
I assume TP13 and TP14 is pin 2 on bouth EL84.
I got 0 VDC and around 0,8VAC on bouth
Offline Travis8
« Reply #18 on: April 08, 2022, 11:04:32 am »
If I touch R20 and R23 i get -12,8VDC but if I test on pìn 2 I get 0 VDC
I check continuity between R20 and pin 2 of v3 and between R23 and pin 2 of v4. It´s correct
Online sluckey
« Reply #19 on: April 08, 2022, 11:45:20 am »
So you have -12v on one side of R20 and R23, but you have zero volts on pin 2 of the EL84s. Not much between those points. Ensure that R20 and R23 both measure 1.5KΩ and are not open circuit. Then measure resistance between V3 pin 2 and chassis. Repeat for V4 pin 2 and chassis. Should be approx 270K and definitely not zero ohms. Report
Offline Travis8
« Reply #20 on: April 08, 2022, 01:18:58 pm »
Bouth around 270kohm. R20 and R23 are ok, not open.
I clean the pin 2 and now I get the correct vdc (-12,8) so it's correct
« Last Edit: April 08, 2022, 03:10:08 pm by RCZ »
Offline Travis8
« Reply #21 on: April 08, 2022, 03:09:42 pm »
Some new ideas?
« Reply #22 on: April 08, 2022, 04:16:48 pm »
Time to do a VAC test on your OT
Offline Travis8
« Reply #23 on: April 08, 2022, 04:28:11 pm »
« Reply #24 on: April 08, 2022, 05:13:47 pm »
This is the sound of the amp at any level
https://drive.google.com/file/d/1WkZa7RMnWxanWrzv7hGmpBUcMGcZ-G5H/view?usp=drivesdk
That’s not doing a VAC test. Unhook the OT primary centre tap, pull the output tubes, and disconnect the OT secondary from the speaker output Jack. Then put a lowish VAC source across the secondary (5 or 6 VAC will work) and measure the resulting VAC between the Primary CT and each output tube socket plate pins. You should get a highish VAC that corresponds with the expected Sec:Pr VAC ratio given whatever voltage your source VAC is on the secondary. What’s more, the VAC across each half of the Primary should be the same. If you don’t get these results, the OT is haddit.
Offline Travis8
« Reply #25 on: April 08, 2022, 05:36:01 pm »
Nice, I'm learning a lot. I dont have a VAC supply, wich one could I use/buy?
« Reply #26 on: April 08, 2022, 06:03:50 pm »
Poor man’s VAC source. Disconnect your PT secondaries and use the 6.3VAC winding
« Reply #27 on: April 08, 2022, 07:03:32 pm »
BTW, it should go without saying, but don't let the loose/bare ends of any windings come into contact with the chassis or you or any other part of the circuit
« Last Edit: April 08, 2022, 07:39:41 pm by tubeswell »
Offline Travis8
« Reply #28 on: April 11, 2022, 10:23:10 am »
The OT is working correctly.
I can order two el84, maybe the problem is there. Becouse I check all the circuit and try new preamp tubes.
Offline Travis8
« Reply #29 on: April 11, 2022, 10:24:04 am »
Also If I turn on the amp and wait a lot (around 30 min) it's work perfectly.
Some ideas?
« Reply #30 on: April 11, 2022, 10:21:25 pm »
What VAC did you get on each 1/2 of the primary? (assuming you put 6.3VAC across the secondary?)
Offline Travis8
« Reply #31 on: April 14, 2022, 06:33:49 am »
Wait, I think I did bad. I will repeat it this week.
Check If I´m doing it correctly:
1- Unhook the OT primary centre tap (Red Cable of OT)
2- Pull the output tubes, disconnect the OT secondary from the speaker output Jack.
3- Disconnect PT secondaries and use the 6.3VAC winding (Green Cables of PT)
3- Connect the Green Cable of PT to the Red Cable of OT
4- Measure the resulting VAC between the Primary CT (Red Cable of OT) and each output tube socket plate pins (Pin 7).
Of course I don't let the bare ends of any windings come into contact with the chassis etc
Offline Travis8
« Reply #32 on: April 14, 2022, 06:34:09 am »
Thanks guys, I´m learning more and more every day in this forum
« Reply #33 on: April 14, 2022, 10:51:26 am »
No. Each end of the PT 6.3VAC winding (after disconnecting from heater circuit) gets connected to each end of the OT secondary winding. You are supplying the OT secondary winding with a 6.3VAC source voltage (so you can determine the resulting VAC on each half of the OT primary).
If you don’t understand this, you probably should take your amp to a tech.
Offline Travis8
« Reply #34 on: April 14, 2022, 10:53:36 am »
Ok, that was what I mean, I understand it thanks!
Let me do it this week, thanks again
Offline Travis8
« Reply #35 on: April 14, 2022, 10:58:43 am »
I write it again:
3- Connect the Green Cables of PT to the secondary cables of OT.
4- Measure the resulting VAC between the Primary Center Tap (Red Cable of OT) and each output tube socket plate pins (Pin 7).
« Last Edit: April 14, 2022, 11:05:16 am by Travis8 »
