September 17, 2026, 09:41:41 am
Hoffman Amps Forum image Author Topic: Negative bias connection on GZ34  (Read 5197 times)
Offline Bieworm
  • I like it loud!
« on: April 11, 2022, 07:44:12 am »
Hey ampaholics unanymous!!
I have a rather stupid question.. posing it anyway.
The negative bias connection on a GZ34 rectifier should be at pin 4 AFAIK. Suppose you put safety diodes on it.. where do I put the neg bias connection? Option A or B ?
My gut feeling says option A, for it's still AC at that spot, but am I right?
Thanks!
Re: Negative bias connection on GZ34
« Reply #1 on: April 11, 2022, 07:47:55 am »
Option A.
Offline Bieworm
  • I like it loud!
« Reply #2 on: April 11, 2022, 07:53:02 am »
« Reply #3 on: April 11, 2022, 08:25:29 am »
Thanks!
The banded end of each SS diode goes to each GZ34 plate pin (Pins 4 and 6). Pins 5 and 7 have no electrical connection to the tube (and so are available for mounting the other lead of each diode for hookup to the High Tension winding).
(The B+ cap connection goes to Pin 8)
