September 16, 2026, 11:35:49 pm
Hoffman Amps Forum image Author Topic: hoffman switching and DC board grounding question (AGAIN)  (Read 5568 times)
Offline Curranm
« on: April 11, 2022, 09:03:19 am »
I want to use up the last of my Hoffman boards which take the AC heaters and rectify them to 5vDC for relay switching. I had great success with adding a transistor an RAC03-05SK 120vAC to 5vDC converter in another amp for foot-switching between channels. SO the Hoffman board use a "floating" ground. me heaters are CT to ground. can I implement this transistor setup with the "floating" ground system of the Hoffman board?
Re: hoffman switching and DC board grounding question (AGAIN)
« Reply #1 on: April 11, 2022, 09:26:29 am »
Sure. But do not connect any part of your circuit to chassis ground.
Offline acheld
« Reply #2 on: April 11, 2022, 09:55:51 am »
Sorry if this is off topic, but I'm curious what transistor does for you in this circuit?
I've been looking at the Dumble switching circuits recently, and they are bone simple, with a switch turning power "on" or "off" at the relay -- ie, no transistor in switching circuit.
Offline Curranm
« Reply #3 on: April 11, 2022, 10:23:36 am »
thank you got the info! and yes NOTHING goes to chassis with this part of the circuit! I did that on my 1st hoffman board! the smoke was MAJIK and MAJESTIK............
as far as the transistor it SHOULD be a 2N3906 NPN. I have it marked as a 2N3904 which is wrong
« Reply #4 on: April 11, 2022, 11:03:11 am »
It's a switch. With SW1 open the transistor is turned on and the relay is energized. With SW1 closed the transistor is turned off and the relay is de-energized.
« Reply #5 on: April 11, 2022, 12:16:17 pm »
I think he wonders: what is the advantage over a no-transistor connection?
Offline thetragichero
« Reply #6 on: April 11, 2022, 08:35:53 pm »
2n3906 is silicon pnp (the complementary pnp to 2n3904). not meaning to stir up an argument, just making sure whoever finds this on google isn't led astray (also want to add to my knowledge since i have yet to make a channel switcher): what transistor are you using? if it is pnp the schematic isn't quite right
