September 16, 2026, 07:42:28 pm
Hoffman Amps Forum image Author Topic: Preamp only build  (Read 4421 times)
Offline joesatch
  • save me from myself.
Preamp only build
« on: April 12, 2022, 01:51:50 pm »
2204 circuit. Where between the cathode follower and the PI would i tap to the output jack of my preamp build?  Wire the MV wiper to the output jack directly?
Offline T Wilcox
  • Trust me I know what I'm doing - Sledgehammer
Re: Preamp only build
« Reply #1 on: April 12, 2022, 04:03:32 pm »
Right off the master to the output jack!
http://www.ceriatone.com/ceriatone/wp-content/uploads/2016/09/JCM800_2204Ceriatone.jpg
treat your preamp output the same as the FX loop send in above layout
If you wanted to make it switchable to instrument level you can add a voltage divider and toggle as well
I attached a snorkler layout that has both line level and instrument out jacks for reference in this case the designer used 2 jacks rather than toggle like I suggested above
« Last Edit: April 12, 2022, 04:09:51 pm by T Wilcox »
Offline joesatch
« Reply #2 on: April 12, 2022, 04:20:22 pm »
Outstanding my man!  :worthy1: :l2:
