September 19, 2026, 06:43:32 am
Hoffman Amps Forum image Author Topic: Channel switching  (Read 6340 times)
Offline Johnnydoright
Channel switching
« on: April 20, 2022, 12:24:29 pm »
I am wanting to install channel switching on my 5E3 clone, but not sure where in the circuit to install this... I have the needed parts, but am not sure how to connect it. Any layouts or schematics for this would be appreciated. As usual, this project is probably a bit beyond my skill level, but with your folks help, I have got great results in the past, and am having so much fun while learning how all these things work. Thanks a lot!
Re: Channel switching
« Reply #1 on: April 20, 2022, 01:19:02 pm »
You'll have to identify what and where you are trying to switch.
The 5E3 is a single channel amp.
« Last Edit: April 20, 2022, 02:53:04 pm by SILVERGUN »
« Reply #2 on: April 20, 2022, 01:33:58 pm »
I separated the channels and voiced the normal channel differently, I think. What I would like to do is switch from the Normal channel to the Bright channel, if that is possible? I used the Rob Robinette Deluxe layout. Both channels sound great, so I want to be able to use them😃
« Reply #3 on: April 20, 2022, 01:41:22 pm »
« Last Edit: April 20, 2022, 01:44:51 pm by pdf64 »
« Reply #4 on: April 20, 2022, 04:14:22 pm »
Here's how that could look if you use one input
« Reply #5 on: April 20, 2022, 06:32:14 pm »
So it looks like I just run to my relay (got the kit from Doug's site) from my normal input, split it at the relay, and send it to pins 2 and 7 from the relay. Looks like that will work to me. Great! I always like getting feedback from you fellas, before I make such changes, as I seem to have less smoke and flames that way. One more question, only 1 input on the amp then? Nothing except the channel switch to the other channel?
« Reply #6 on: April 20, 2022, 07:56:18 pm »
... use an external AB box
+1 vote for ^this^ type of channel selection for a tweed amp, or an 'ABY' box. (You're still going to be lugging an extra cable and footswitch around for a footswitchable relay anyway). 'Stereo' pedals/boards are also great.
These pedals have buffered outputs with independent level controls and you can drive 2 amps (or 2 amp channels) from the outputs with only 1 guitar going into it. 'Swat I use https://www.morleyproducts.com/gold-series-aby-mix/
« Reply #7 on: April 21, 2022, 04:35:18 am »
Haha, my AB box is somewhat lower tech (and cheaper!), just a metal box with 3jacks and a DPDT footswitch.
But I get the impression that the OP has bought a relay board and is itching to use it  :icon_biggrin:
Offline RadioComm
« Reply #8 on: April 21, 2022, 07:01:02 pm »
Another option would be to build a motorized knob adjuster.
Neil Young uses one (the whizzer) for his 5E3:
https://el34world.com/Forum/index.php?topic=28480.msg313651#msg313651
Below is a guitarist's project page for one. Built it for his Orange Dark Terror Head. He uses an Arduino and also provides on the page a link to his software on GitHub.
http://trigonometrie.bplaced.net/blog/terrorbot
The link to the software he provides on GitHub:
https://github.com/fichl/terrorBot
ttfn
