September 08, 2026, 03:50:12 pm
Hoffman Amps Forum image Author Topic: Line Out on a 5E3  (Read 4811 times)
Offline Geezer
Line Out on a 5E3
« on: June 18, 2005, 05:45:31 am »
        > Line Out on a 5E3
<< Prev Topic | Next Topic >>
Author  Comment
Hurricane
Junior tube assistant
(3/25/04 9:20 am)
 Line Out on a 5E3
 Has anyone tried converting the extra speaker jack on a 5E3 into a line out , as suggested in the Gerald Weber book ?
Does it work, ie do you get the whole tone of the amp ? If so, and if it is a worthwhile mod, can it be made adjustable ? I could use the power section of my Hot Rod Deluxe as a slave amp, but there's no level control.
Thanks.
Hurricane.
ernie jr
(3/25/04 11:43 am)
 line out
 i have added a line out on my sunn 200s,
it keep the same sound. i used a 100K ohm 2 watt from the 8 ohm out put to the line out jack, ground to ground
and a 1200 ohm resistor across the hot/ground of the line out jack.
hope this helps
this lets me get a "tube type" sound out of my sunn concert bass amp when i piggy back it off my tube amp.
ernie
Lucid Alice
Senior tube assistant
(3/25/04 8:11 pm)
 Re: line out
 Ernie,
Are you running that into the slave input on the back of the concert, or through the normal input?
I'm not sure if there is a difference between a preamp output level for a slave input and a line out level for a mixing board, thus the inquiry. (Maybe they are the same?)
ernie jr
(3/26/04 7:18 am)
 Re: line out
 i run the line out into brite input on the concert bass.
never had any problems. when i want it louder, i just have to adjust the volume on the tube amp, and both get louder.
hope this helps.
ernie
Hurricane
(3/26/04 8:02 am)
 Re: Line Out on a 5E3
 Thanks. In fact, I found details of the adjustable mod in another article. Worth a go, for the sake of a couple of resistors.
trescat
(3/27/04 9:14 pm)
 Here is a good link on adding a line out
 Hurricane, Check this link on adding a line out , its very informative.
www.rru.com/~meo/Guitar/A.../ezlo.html
Trevor
Leevi
(3/28/04 2:13 pm)
 line out
 Please check the Matchless Hurricane, there is a line out.
/Leevi
www1.korksoft.com/~schem/...ricane.pdf
 Topic Commands
Powered By ezboard® Ver. 7.32
