September 08, 2026, 11:23:07 am
Hoffman Amps Forum image Author Topic: DIY Pickup Winder on a Budget!  (Read 10044 times)
Offline rake
« on: May 01, 2022, 03:31:15 pm »
Hey y'all My little shop of guitar repairs has been quite busy.
Had a few guys with dead pickups so I decided to look into a winder.
(I worked in a shop years ago and we had a winder there)
Long story short, I can't justify the cost of the commercial winders
so I made one! Cheap too! LOL!
Here's what you need to make it go round and round.
Power Supply $7.49
https://usa.banggood.com/1pcs-Geekcreit-AC-100-240V-to-DC-12V-5A-60W-Switching-Power-Supply-Module-Driver-Adapter-LED-Strip-Light-p-1921232.html
Speed controller $14.99
https://usa.banggood.com/7-70V-30A-PWM-DC-Motor-Speed-Controller-Switch-Control-12V-24V-36V-48V-70V-p-1878495.html
DC motor $19.99
https://usa.banggood.com/HANPOSE-775-Motor-DC-12V-24V-80W-150W-288W-DC-Motor-Large-Torque-High-Power-DC-Motor-Double-Ball-Bearing-Spindle-Motor-p-1441968.html
Digital punch counter $6.99
https://usa.banggood.com/0-99999-LCD-Digital-Display-Electronic-Counter-Punch-Magnetic-Induction-Proximity-Switch-Reciprocating-Rotary-Counter-p-1938618.html?cur_warehouse=CN&rmmds=search
I ran into a slight snag with the counter. Seems it does not shut off and the battery just dies in a couple days and it's not easy to remove. So I used this inexpensive circuit to drop the 12v from the power supply to 1.5v to run the counter.
Solid state has no soul........
Offline rake
Re: DIY Pickup Winder on a Budget!
« Reply #1 on: May 01, 2022, 03:41:59 pm »
The hot leads of the reg are simply soldered to the battery terminals of the counter.
You'll need a DPDT switch for rotation a SPST switch for power and a fuse holder and fuse
for safety.
The pot comes with the speed controller.
I used 3/8 id bearings for the shaft.
I made aluminum pulleys at about a 3 to 1 ratio.
belt was a large o-ring.
there's no reason the pulleys and bearing holders can't be hardwood.
I sourced the bearings and other components from Digikey.
If you need any other pics or info just holler!
