September 08, 2026, 11:23:06 am
Hoffman Amps Forum image Author Topic: Speaker Question  (Read 6501 times)
Offline jy67
Speaker Question
« on: May 05, 2022, 05:58:33 am »
Would 2 - 8 ohm 25 watt Weber 10F15OT's wired in parallel handle either a Blackface Bandmaster (40w) or Bassman (50w) head?
Re: Speaker Question
« Reply #1 on: May 05, 2022, 06:22:15 am »
It depends on how the amp is used. Clean will probably be fine, overdriven perhaps not.
Overdriven power will probably be around 50% + higher than than rated (ie clean) power output.
Offline jy67
« Reply #2 on: May 05, 2022, 07:15:22 am »
Overdriven with pedals, or just cranking the volume?
« Reply #3 on: May 05, 2022, 01:36:57 pm »
It makes no difference really, 6 of one and half a dozen of the other. All that matters is whether the output stage gets pushed hard into overdrive.
