September 15, 2026, 12:10:53 am
Hoffman Amps Forum image Author Topic: Tone stack & NFB switch  (Read 4007 times)
Offline dwinstonwood
« on: May 07, 2022, 02:44:02 pm »
I'm thinking about a single SPST switch that would cause a pretty big change in my current amp project.
Is an AB763 type tone stack bypass simply a switch that lifts the Mid pot's ground connection?
I would like to combine this with breaking the NFB connection to the speaker terminal, both with the flip of a single On/Off switch.
Any reason this wouldn't work?
Thanks!
Re: Tone stack & NFB switch
« Reply #1 on: May 07, 2022, 03:25:54 pm »
Yes. You need a DPST switch.
« Reply #2 on: May 07, 2022, 04:21:30 pm »
Thanks! Of course, that makes sense now that you say it!
It's two separate circuits I'm breaking that can't be shorted together on a SPST.  :BangHead:
« Last Edit: May 07, 2022, 04:25:31 pm by dwinstonwood »
« Reply #3 on: May 08, 2022, 10:38:57 am »
I don't want to run speaker jack wires back and forth across the chassis to this front-mounted switch. So, I'll try this setup and see what I think. It's easy to disconnect if it turns out to be a bad idea. And, I can always add a second switch on the back of the chassis next to the speaker jack to disconnect the NFB.
"ON" = tone stack and bright cap
"OFF" = tone stack bypassed and no bright cap
