September 15, 2026, 02:12:29 am
Hoffman Amps Forum image Author Topic: Vox style CUT control in SE amp  (Read 5675 times)
Offline dunner84
« on: May 08, 2022, 02:51:38 pm »
Hello,
I am starting a new project, and I am wondering if anyone knows if its possible, or has some tips to add a Vox style cut control to a SE amp. The amp is a single EF86 to SE EL34, and essentially I would like to add some high end control without a tone knob.
Cheers
Re: Vox style CUT control in SE amp
« Reply #1 on: May 08, 2022, 03:10:02 pm »
The Vox style cut control requires a push/pull amp.
« Reply #2 on: May 08, 2022, 03:28:26 pm »
There are other tone controls you can make work on an EF86, with a  combination of permanent HF boost* in parallel with pot and LF** cap (in series) - which gives a permanent HF boost that you can alter by dialing out the resistance in series with the bigger cap.
*i.e. smaller caps at Ck or Cg2
**bigger cap
« Reply #3 on: May 08, 2022, 04:21:02 pm »
… add a Vox style cut control to a SE amp. … I would like to add some high end control without a tone knob…
The cut control is a tone control. A simple -6dB/octave low pass filter, when the control is set for minimum resistance.
In a SE circuit, it could be implemented as per that of the 5B6 Bassman https://el34world.com/charts/Schematics/files/Fender/Fender_bassman_5b6_schem.pdf
In a guitar amp, the 0.1uF cap may be excessive, I suggest 10nF would probably provide a similar effect to the 4n7F in the cut circuit (as it would be interacting with 1 anode resistance, rather than the series pair of the LTP).
Offline jordan86
« Reply #4 on: May 08, 2022, 04:48:52 pm »
Not sure what your desire is for “control” or “variability”, but I just added a conjunctive filter on my SE and I find it to be VERY useful at knocking off some of the harsh trebles. I really like .0015uf and 5K resistor. You could do two different value caps on a DPST to have options.
Recent thread is here.
https://el34world.com/Forum/index.php?topic=28806.0
Offline dunner84
« Reply #5 on: May 08, 2022, 06:09:28 pm »
Thanks for the input. The conjunctive filter sounds interesting. I read the thread. Do you have a schematic for how you implemented it?
Cheers
Offline dunner84
« Reply #6 on: May 08, 2022, 06:14:03 pm »
With regards to the conjunctive filter, I checked a carmen ghia schematic. I assume its the 10k - 0.0022uf in series across the OT primary?
Offline jordan86
« Reply #7 on: May 08, 2022, 07:40:43 pm »
Yup. That’s it. I liked a 5K resistor better. Less compressed in the feel. Carmen Ghia is PP so the values aren’t exact for your context. I like .0022 though. Didn’t care for .0047. Total mud. Here’s a site where some guy made sound samples. About half way down the page. My findings were similar. While I like BRIGHT amps it really smooths out the high end in a good way.
https://www.cs.cmu.edu/~ehn/ax84/
