September 15, 2026, 05:03:35 pm
Hoffman Amps Forum image Author Topic: Mesa 50/50 Ch. A very low output  (Read 4365 times)
Offline JustMike
« on: May 15, 2022, 09:27:52 am »
 This amp is an earlier rev than the one in the schematics library. Mine doesn't have a choke for one. I've got good +VDC at node C (450v) , but at the plate on the other side of R282 (82k), I've got 126v and the schemo shows 316v.
 Any ideas?
I'm learning...
Re: Mesa 50/50 Ch. A very low output
« Reply #1 on: May 15, 2022, 09:42:11 am »
what's happing on the other plate?
« Reply #2 on: May 15, 2022, 10:23:48 am »
Do you have a 12AX7 or some other 12A_7 in that position?
« Reply #3 on: May 15, 2022, 12:20:56 pm »
And the common cathode?
Diagnosis by checking just one point in a circuit with more than two parts requires brilliance or great luck.
Offline Keppy
« Reply #4 on: May 15, 2022, 12:49:03 pm »
If you need a schem, try contacting this poster. It looks like he hasn't been active in about 6mos, so DM me if you really need it and can't reach him through the forum.
Offline Latole
« Reply #5 on: May 15, 2022, 12:56:16 pm »
Remove V2 ; how many volts ? Did you get the 316 V ?
Offline JustMike
« Reply #6 on: May 15, 2022, 02:02:29 pm »
Thanks all. It was a bad P.I. tube. BUT the owner just told me that originally the amp was redplating. He replaced the 4 output tubes and then noticed that channel A was not working. So now I have to monitor for redplating.
I'm learning...
