September 15, 2026, 04:39:45 am
Hoffman Amps Forum image Author Topic: Hoffman plexi 50 questions  (Read 6585 times)
Offline Stuff4bikes
« on: May 19, 2022, 09:35:36 pm »
The layout shows all the can caps grounded together.......
I am one of the few people who does not like can caps....
And I have dozens of 47uf 500v caps on hand.....
I am going to use a single 100uf and 4-47uf's in
A fender(ish) dog house alignment...underneath the amp though..
How far away do you keep the impedience selector switch from the filter caps...?
Should I ground all the caps together or A,B,C grounded together and D,E grounded seperate?
I ordered a faceplate from modulus and it will have 4 holes for the inputs, the layout only
Calls for 2.
Can I just parralel another input jack for each channel?
Re: Hoffman plexi 50 questions
« Reply #1 on: May 20, 2022, 07:15:17 am »
Ground diagram from the library page is here
https://el34world.com/charts/grounds.htm
« Reply #2 on: May 20, 2022, 08:15:52 am »
The schematic shows how to wire dual input jacks.
Somewhere between 1/4" and 1/4 mile.
« Last Edit: May 20, 2022, 08:18:37 am by sluckey »
Offline Williamblake
« Reply #3 on: May 20, 2022, 08:27:50 am »
[/quote]
Just dont go metric.
Offline Stuff4bikes
« Reply #4 on: May 20, 2022, 08:54:42 am »
Thanks for all your help.
