September 15, 2026, 10:13:59 pm
Hoffman Amps Forum image Author Topic: How Low Can I Go? (cathode bias resistor)  (Read 7678 times)
Offline Fraggy0117
« on: May 24, 2022, 09:22:45 am »
I'm tuning a SE amp that has a switch to select a cathode bias resistor for a 6V6 and a 6L6. I started with 670r & 750r, respectively. Didn't get high enough plate dissipation, so I went to 400r and 225r but it's still a little bit low.
Basically, how low can I go before there are negative side effects? Playing with a bias calculator I think my next steps are 300r (6v6) and 120r (6L6), but I know from the last time that reducing the resistor value won't exactly give me the plate dissipation that the calculator says (since other voltages will change).
I know it'll never be perfect and it's a compromise; I have an undersized PT, two different power tubes using the same power section, etc. Just curious for any insight on when to call it.
If it helps, here's my voltages (and I'm using this calculator https://robrobinette.com/Tube_Bias_Calculator.htm):
6V6 (JJ6v6)
Plate-to-Cathode: 318v
Kr voltage: 14.6v
Kr value: 400r
78% dissipation
6L6GC (Russian mullard)
Plate-to-Cathode: 292v
Kr voltage: 13.13v
Kr value: 225r
48% dissipation
Re: How Low Can I Go? (cathode bias resistor)
« Reply #1 on: May 24, 2022, 09:41:40 am »
the lower that value goes, the less "headroom" you have, the earlier the distortion.
post the R value so we can do some oldschool math, just to verify your calculator
Vk/Vr = Tube current
Vp - Vk * Itube is a smidge less than Pdiss, but close enough
« Reply #2 on: May 24, 2022, 09:44:25 am »
Dissipation is just a limit, work out a suitable operating point (see link) then check it idles within the design centre limit.
http://www.valvewizard.co.uk/se.html
« Reply #3 on: May 24, 2022, 09:54:25 am »
Cathode biased amps typically run 90% to 100% plate dissipation, some even higher. I would not exceed 100%.
« Reply #4 on: May 24, 2022, 10:37:25 am »
Is your amp using a tube rectifier? Got a schematic?
« Reply #5 on: May 24, 2022, 11:12:26 am »
It is fine the way it is. If you actually wanted the MOST power, you would not be dinking with an inefficient one-tube design.
Offline Fraggy0117
« Reply #6 on: June 01, 2022, 03:49:17 pm »
Took me a while to update my schematic — I've tweaked it a lot since the original. Thank you all for the replies
I uploaded it and attached it: https://imgur.com/a/AKU6ah2
Solid state rectifier, and light OT/PTs. Partially as an adventure in using in-production parts and to see if there was any mojo in using undersized OTs like I've heard about in Silvertones.
Very fair. I wasn't looking for more power, necessarily, just seeing if the tone would be any better. It sounds great as it is currently, but I'm hoping to squeeze every bit I can.
6v6 cathode resistor is 400 ohms and 6L6 is currently 225 ohms.
This is probably the best method. I should've known there's always more math I can do!
« Reply #7 on: June 01, 2022, 04:41:45 pm »
:laugh:
the fuzzy math is my favorite
Offline Williamblake
« Reply #8 on: June 03, 2022, 07:28:07 am »
Always nice to see new ideas about driving a reverb tank. How happy are you about that?
Offline Fraggy0117
« Reply #9 on: June 03, 2022, 12:06:26 pm »
I haven't actually hooked up that portion of the circuit - I wanted to tweak the rest of it first. As drawn it is a copy of what was traced from the Benson Monarch and I think it shares some similarities with some of the Ampeg amps (if I'm remembering the discussion correctly). I'm hoping it'll drop in with minimal tweaking but I'll be sure to update once I've got it hooked up.
