September 08, 2026, 04:41:28 pm
Hoffman Amps Forum image Author Topic: Fender champ 12 Effectrode mod  (Read 7538 times)
Offline Kesi from Hungary
« on: May 29, 2022, 01:27:38 pm »
Hello, does anyone have experience with the Effectrode mod on a Fender champ 12. I'm working on the mod and finished the first part of the gain channel.  Now the clean part.  In the diagram of Effectrode a new/extra 220K resistor is drawn with a line just above resistor R21.  I don't know where to put it.  Instead of jumper W 5?  Or something else?  I'll try to post a picture and schematic.https://el34world.com/Forum/Themes/default/images/post/xx.gif
Re: Fender champ 12 Effectrode mod
« Reply #1 on: May 29, 2022, 01:44:44 pm »
« Reply #2 on: May 29, 2022, 01:51:50 pm »
very fast answer.
You mean parallel? Thats makes it 440k.
« Reply #3 on: May 29, 2022, 02:09:47 pm »
very fast answer.
No. Replace R21 with a jumper wire. Replace R16 (47K) with a 220K. You could just use the removed 220K rather than using a new one, that is if you don't booger up the original 220K.
« Last Edit: May 29, 2022, 02:12:06 pm by sluckey »
« Reply #4 on: May 29, 2022, 11:14:38 pm »
Thanks for solving the problem.  This week the last parts will arrive and then I can finish the project.  Regards Kesi
Offline pietrocop
« Reply #5 on: February 04, 2026, 07:51:10 am »
Hi, have you completed the modification? I did it myself recently and had the same doubt as you. I followed the suggested approach (removed R21 and connected without a resistor), but I don’t like the overall result. The Overdrive channel has improved, but the channel’s volume has increased a lot and it already distorts at 1. How are you finding the modification?
« Reply #6 on: February 05, 2026, 05:45:52 am »
"Hi, I wasn’t satisfied with the mod or the other variants I tried either. And that’s exactly the problem with this amp. You either love it or you don’t, but with this amplifier it’s really hard to have both a good clean channel and a good dirt channel."
