September 16, 2026, 03:57:07 pm
Hoffman Amps Forum image Author Topic: Lamp limiter- nada  (Read 5314 times)
Offline mrhudson27
Lamp limiter- nada
« on: June 06, 2022, 12:52:10 pm »
Hey, all. Another neophyte query: attempted to power up a 90’s Ampeg Reverberocket R50H head that has been stored for > 10 years, fully operational when shelved. Plugged into lamp limiter (homemade, proven track record) and NO light. Not bright, not dim- nothin’. Amp no power up. About to pull chassis & check fuse. I get short vs no short, but what does darkness tell me?
Flogging & belittlement anticipated and welcomed (in a time crunch- haven’t researched threads here yet)
Re: Lamp limiter- nada
« Reply #1 on: June 06, 2022, 01:08:04 pm »
Darkness tells you that either there is no current flowing (open circuit) or the current is so small that it's not enough to make the bulb filament glow.
« Reply #2 on: June 06, 2022, 01:15:52 pm »
A broken fuse ?
Oxidation ?
Broken wire in the Line to Amp path ?
Who can Say
You must practice some further investigation
Offline Latole
« Reply #3 on: June 07, 2022, 02:52:53 am »
Is your bulb lamp is good ?
Your bulb lamp curent limiter; what kind of bulb ? You need a old style incandescent bulb; 75 to 100 watts.
Did it work ( light) on a good working amp ?
After you say yes, check the amp
Offline Keppy
« Reply #4 on: June 07, 2022, 09:34:14 pm »
I check my light bulb limiter by plugging a heat gun into it. That draws enough current to get the bulb nice & bright.
Aside from lighting up if there's a short, the limiter doesn't tell you much. It's there to keep you from blowing fuses & circuit breakers. If it doesn't light up, it's time to start checking voltages within the amp.
