August 05, 2026, 04:12:32 pm
Hoffman Amps Forum image Author Topic: Help with AS-05T200 PT rectification  (Read 4486 times)
Offline joesatch
  • save me from myself.
« on: June 09, 2022, 10:13:00 pm »
This toroidial PT is outputting 210vac into the FWB and i'm measuring 210VDC on the rectifier out tap. I've never seen this. The voltage rectified is the same. What's wrong here? Shouldn't it be much higher? I have the reservoir cap disconnected.
Re: Help with AS-05T200 PT rectification
« Reply #1 on: June 09, 2022, 10:15:58 pm »
You have the reservoir cap disconnected.
Try connecting it.
Offline joesatch
« Reply #2 on: June 09, 2022, 10:16:16 pm »
i think because the cap is disconnected, the peak voltage isn't being sustained. I' guessing this is the issue
« Reply #3 on: June 09, 2022, 10:18:23 pm »
Try connecting it.
Offline joesatch
« Reply #4 on: June 09, 2022, 10:27:35 pm »
ok i formed the cap. it's reading 286vdc. All good. I knew i forgot something. Thanks!
