September 21, 2026, 06:19:24 am
Hoffman Amps Forum image Author Topic: PT wiring question / confirmation  (Read 4664 times)
Offline Bieworm
  • I like it loud!
« on: June 13, 2022, 02:36:03 am »
Hi guys!
There is something in need to get confirmed. Am I correct to assume that when I use the secondary HT winding like in the drawing that I should end up with a 'kind of' half power switching? I mean, I could use the winding like that, no?
Thanks in advance...
Re: PT wiring question / confirmation
« Reply #1 on: June 13, 2022, 05:29:18 am »
The idea is sound but your voltages are wrong. You really have 0v-300v-600v which will give you about 848v or 424v into a cap input filter.
The Twin amp does something similar but with lower voltages. Notice that only the output tubes plates and screens are changed while the rest of the amp uses the "high power" voltages. Oh yeah, you must also switch the bias voltage.
IMO The Twin method is more realistic than your idea.
« Last Edit: June 13, 2022, 05:33:45 am by sluckey »
Offline Bieworm
  • I like it loud!
« Reply #2 on: June 13, 2022, 06:13:17 am »
Thanks Steve!
I'd be better off with this one then?
https://www.tube-town.net/ttstore/toroidal-185va-power.html
« Reply #3 on: June 13, 2022, 06:39:14 am »
That gives more practical voltages. If you plan to implement this idea into a real amp then I urge you to study the twin method and copy that instead of simply switching the AC voltage per your drawing.
