September 21, 2026, 02:24:58 am
Hoffman Amps Forum image Author Topic: JTM45 Radiospares Impedance selector  (Read 5746 times)
Offline jrgtwo
« on: June 14, 2022, 02:39:39 pm »
Hey All, wrapping up a JTM45 build and looking to see if anyone has worked with the Mercury Magnetics Radiospares or original Radiospares OT.  Looking to see if it's possible to make a selector switch or something to connect the 6 different OT secondary wires for 16 and 8 ohm operation.
I tried searching this forum and the internet at large but found very little on the topic.
I have some 8 pole jones plugs that may work but they are quite large and will be difficult to fit into the back panel.  I have also thought of maybe using an octal tube plug and socket. Jumper the six wires accordingly and two poles for the speaker load connections.
I can't make it work in my head using a 3pdt or dpdt switch but hoping someone may have hacked something together in the past
At worse I can just hardwire the jacks to 16ohm
OT spec and secondary wiring doc attached
Thanks all!
-Jonathan
Offline JB
Re: JTM45 Radiospares Impedance selector
« Reply #1 on: June 15, 2022, 12:21:05 am »
Yes it’s possible to do this. I was given an original RS Deluxe and use a DPDT to switch between 8 and 16 ohms. I’ll try and find my drawing later or tomorrow.
Offline jrgtwo
« Reply #2 on: June 15, 2022, 11:21:33 am »
Thank you!
Look forward to seeing how you did it with the dpdt switch
-Jonathan
« Reply #3 on: June 15, 2022, 11:42:36 am »
There’s 3 windings, a half winding and 2 quarter windings.
The 2 quarter windings are switched to be in series for 16ohm or parallel for 8ohm.
Just the same as wiring a twin coil pickup for series or parallel.
The half winding is wired in series with the above.
Unfortunately I’m away from my notebooks for a couple of weeks, so no further details for a while.
Offline jrgtwo
« Reply #4 on: June 15, 2022, 12:13:21 pm »
Oh interesting, thank you
I see that the secondary has multiple windings, but your description helps to better understand the secondary wiring in general.  I'll see what I can figure out.
Thanks alot!
-Jonathan
« Reply #5 on: June 15, 2022, 01:47:19 pm »
As I recall, A - F is the half winding.
The windings have a fairly high resistance, so it should be feasible to check which is which.
Don’t switch impedance with the amp operational.
Offline JB
« Reply #6 on: June 15, 2022, 03:39:47 pm »
Hi,
Here's how I did it:
As PDF says above the transformer has a 4 ohm and two 1 ohm secondaries.  With that arrangement I'm measuring approx 9 ohms and 16 ohms.  I used a DPDT switch with the two halves strapped.
Offline jrgtwo
« Reply #7 on: June 15, 2022, 03:45:00 pm »
Y'all are the best
Thanks so much for the help!!
 :worthy1:
-Jonathan
