September 19, 2026, 03:20:59 pm
Hoffman Amps Forum image Author Topic: Raising the 1M resistor on the input.  (Read 5640 times)
Offline valvetones
« on: June 14, 2022, 07:37:37 pm »
Hello!
Been awhile , I hope you all are doing well.
So ive been playing with the EF86 normal channel on my vibroverb build. I built it with the EF86 to put the channels in phase so I could jumper channels.
This was to be able to boost gain and maybe get earlier breakup as well as to have a different tonal palate.
Well, I realized that when I jumper channels , I’m putting the two 1 Meg resistors in parallel, effectively making it 500k and bleeding half my guitar signal to ground before it even hits a grid.
This problem nearly negates the purpose of jumpering the channels in the first place.
I had considered changing the 1M resistors to 2 meg so the two parallel resistors will be 1 meg when channels are jumpered.
But then when there is no jumper and I’m actually only playing one channel, then it will be 2 meg.
What effects electrically and also sound wise might I observe if I used the 2 meg resistors , when only playing through one channel?
Thank you for your insights fellas. Hats off to the moderators.
Re: Raising the 1M resistor on the input.
« Reply #1 on: June 14, 2022, 07:50:29 pm »
Just do it. The difference is minor.
Offline d95err
« Reply #2 on: June 15, 2022, 02:40:25 am »
You are not bleeding half the signal to ground. It is only a small change of input impedance.
1M or 500k will make no significant difference to the signal level (unless there is a huge series resistance infront of it).
Offline nandrewjackson
« Reply #3 on: June 16, 2022, 06:59:18 am »
Could it also be said that the guitar signal coming in "sees" the parallel input grids as lower Z than if they were being used independently?  Or do the input grids retain their individual Z despite being parallel?
« Reply #4 on: June 16, 2022, 01:42:12 pm »
Read a chapter on "parallel resistances".
« Reply #5 on: June 16, 2022, 11:27:35 pm »
I'm familiar with parallel resistances.
1 /  ( [1/R]+[1/R]+[1/R] )
But I was wondering if each grid being part of an active component (triode) would be an exception to the rule. As if the active component (triode) may have a different equation, a different "rule of thumb" for parallel Z, as opposed to parallel passive resistors.
« Reply #6 on: June 17, 2022, 04:08:12 pm »
But the 1Meg is not inside the triode.
Anyway, how would your pickup know?
« Reply #7 on: June 18, 2022, 07:08:31 am »
Pretty much the only loading that the grid presents to the input is its Miller capacitance.
