September 20, 2026, 10:07:17 pm
Hoffman Amps Forum image Author Topic: Steel guitar tube input preamp  (Read 4523 times)
Offline Swampertech
« on: June 17, 2022, 10:48:38 am »
Hello all! Are there any specific parameters for the design of a tube input preamp/power amp for use with a pedal steel guitar. I understand the frequency response needs to be wider than a guitars' (more bass response), and the input impedance needs to accommodate the guitar depending on the pickup used. I read on a steel guitar forum that the first preamp doesn't need a cathode bypass capacitor. Do any of you play pedal steel guitar, and if so what is your favorite amp? Thanks!
Offline uki
  • Hot Tube Hot Sound
    • Uki's Guitar Trip
Re: Steel guitar tube input preamp
« Reply #1 on: June 17, 2022, 10:57:47 am »
https://soundcloud.com/ukiuki
Offline Swampertech
« Reply #2 on: June 17, 2022, 11:03:13 am »
Thanks UKI, I did see one article that mentions a 4 band EQ, one that controls the mids better. I do think a parametric EQ would work. Again, thanks.
