September 19, 2026, 06:52:51 am
Hoffman Amps Forum image Author Topic: Transistor used for tremolo?  (Read 6341 times)
Offline BadCatCubII
« on: June 20, 2022, 12:22:02 pm »
Hi everyone,
Long story short, I'm planning to build a single-ended amp with tremolo hoping to use only one triode of a 12ax7 for that effect.
I would like to vary the bias of a pre-amp tube, and I found this thread here: https://el34world.com/Forum/index.php?topic=9255.0
I am especially interested in the attached schematic from that thread but can't find the transistor listed, and don't know squat about transistors.
My questions are:
1) Will this work if I attach the port marked "trem" to the cathode of a preamp tube?
2) I can't find the mosfet that is listed in the schematic, will this one work as a subsitute? https://www.digikey.com/en/products/detail/onsemi/SSN1N45BTA/1052982
Anything else I need to know?
Thanks in advance,
Ben
Re: Transistor used for tremolo?
« Reply #1 on: June 20, 2022, 02:57:28 pm »
« Reply #2 on: June 20, 2022, 03:09:09 pm »
The LED is backwards.
Offline BadCatCubII
« Reply #3 on: June 20, 2022, 05:28:54 pm »
Thanks, Sluckey and Shooter!
I had noticed that the LED was opposite from the way it is on Merlin's site, so thanks for confirming that, Slucky.
I don't doubt what you say about needing a P-channel, Shooter, but I was able to find a datasheet for the MOSFET in the schematic and it is a 450 volt P-Channel. That is why I suggested the one I did. How do I know what i need?
Do you think this would work: https://www.digikey.com/en/products/detail/microchip-technology/VP0550N3-G/4902412
Thanks again!
« Reply #4 on: June 20, 2022, 11:16:48 pm »
you're looking for a 500V P-Channel mosfet
NO!! It is a N channel! On the schematic and on the datasheet!
« Reply #5 on: June 21, 2022, 03:31:21 am »
 :BangHead:
used the transistor "jingle"
N(ot) pointing IN
P(ointing) IN
Offline Joel
« Reply #6 on: June 21, 2022, 04:18:05 am »
I built this Mosfet tremolo into my Single Channel Reverb about 18 months ago: https://el34world.com/Forum/index.php?topic=26928.msg295792#msg295792  Still happy with it.
The mouth of a happy man is filled with beer  - Egyptian Proverb
Offline thetragichero
« Reply #7 on: June 21, 2022, 09:04:26 am »
:BangHead:
N(ot) pointing IN
P(ointing) IN
works for bjt
i was scratching my head at all the mention of p-channel fets (i'm sure i have a few, but i have about 500x more n-channel) but hadn't bothered to open up a schematic so just kept my mouth shut
Offline BadCatCubII
« Reply #8 on: June 21, 2022, 09:36:12 am »
This is helpful, thanks! Like I said, I am totally clueless about transistors. :)
That looks super interesting, Joel, I have some reading to do. :)
