September 19, 2026, 06:08:29 pm
Hoffman Amps Forum image Author Topic: Bias circuit question.  (Read 5344 times)
Offline joesatch
  • save me from myself.
« on: July 05, 2022, 08:56:38 am »
typical plexi style bias circuit. What resistor would i change below if more negative bias voltage is needed?
Offline thetragichero
Re: Bias circuit question.
« Reply #1 on: July 05, 2022, 09:27:06 am »
decrease r54 or install a resistor between p1 and ground (this second one is a better idea to me because then you remove the possibility of turning the bias voltage all the way down to zero. maybe it's me but i try to make things as "idiot proof" as possible)
« Reply #2 on: July 05, 2022, 10:09:05 am »
A lot of people refer to R63 as the "bias range" resistor. Decrease size for more negative voltage.
Decreasing R54 will result in LESS negative voltage. There is no danger of reducing the negative voltage to zero with the circuit as is.
« Last Edit: July 05, 2022, 10:19:03 am by sluckey »
« Reply #3 on: July 05, 2022, 12:26:28 pm »
ahhh picture is missing the top which would show bias voltage being taken from the junction of r54 and r59. my bad, see above correct answer
Offline nandrewjackson
« Reply #4 on: July 05, 2022, 05:46:19 pm »
+1 for decrease R63
