September 18, 2026, 11:09:41 pm
Hoffman Amps Forum image Author Topic: Dual 50 Amp  (Read 5941 times)
Offline Big_Mike
Dual 50 Amp
« on: July 10, 2022, 12:52:58 pm »
Finally getting back into building amps, and am thinking of building Sluckey's Dual 50.  Anyone built one?  It would be really neat to have a Marshall 1987 and 2204 in one package.  Anyone compare the Dual 50 with an actual 1987 and 2204?
Offline Bieworm
  • I like it loud!
Re: Dual 50 Amp
« Reply #1 on: July 10, 2022, 03:15:17 pm »
Built one last year. Great amp! Be aware both amps share the same tone stack, so forget about making it switchable.. both require different settings
Offline Big_Mike
Re: Dual 50 Amp
« Reply #2 on: July 10, 2022, 04:02:35 pm »
Thanks for the info!  I don't intend to make it switchable, so the shared tone stack is not really an issue.  Would it be possible to have two separate tone stack controls for each amp?  It would make for more knobs on the front, but might make switching back and forth easier.
Re: Dual 50 Amp
« Reply #3 on: July 10, 2022, 07:36:43 pm »
Sure.
Offline Big_Mike
Re: Dual 50 Amp
« Reply #4 on: July 12, 2022, 11:37:53 am »
Cool to know, would you just make the switch between the 1987 and 2204 sides after the tone stack?  Just curious how you would do two separate tone stacks.
Re: Dual 50 Amp
« Reply #5 on: July 12, 2022, 11:45:29 am »
Build two complete preamps. Then connect a 220K resistor to the wiper of each treble pot. Tie the other ends of the resistors together and connect to the MV hot lug. Connect the wiper of the MV to the PI input cap.
The two 220Ks make a passive mixer and the MV works for both channels. If you rather have a switch just replace the two 220Ks with a SPDT switch.
Offline Apexelectric
Re: Dual 50 Amp
« Reply #6 on: July 16, 2022, 05:16:11 pm »
Converted an old Traynor YVM-1 into a Dual 50 and did make it foot switchable for the channel, bright and jumpered options.
It's never a dumb question if it prevents a dumb mistake.
