August 03, 2026, 04:14:57 pm
Hoffman Amps Forum image Author Topic: Negative Feedback Causing Oscillation?  (Read 10391 times)
Offline AHeck
« on: July 15, 2022, 04:00:22 pm »
Good afternoon, hope you are all very well and thanks for considering this post.  This is an amp I put together and I'm having some stability issues at very high volumes only when I engage the NFB options. The more feedback, the more howling.  What have I not considered?
Also wondering about the P to S voltage on V1?  is this extreme?
The amp sounds good, but it's not as stable as one I built earlier this year.
Thanks for the help.
« Last Edit: July 15, 2022, 04:37:57 pm by AHeck »
Offline AHeck
Re: Negative Feedback Causing Oscillation?
« Reply #1 on: July 15, 2022, 04:48:35 pm »
This is the speaker out and NFB circuit.
« Last Edit: July 15, 2022, 05:00:54 pm by AHeck »
Offline AHeck
« Reply #2 on: July 15, 2022, 05:06:57 pm »
Layout Picture
Offline AHeck
« Reply #3 on: July 15, 2022, 05:07:47 pm »
Another Layout Picture
Offline nandrewjackson
« Reply #4 on: July 15, 2022, 06:08:03 pm »
470R and 1K should be huge amounts of NFB.
Is the black through-panel thing the impedence switch?
It's my understanding that the NFB resistors are to be tied to only one of the OT taps. If that black receptacle is the impedence switch, you're also switching your NFB back and forth between OT taps.
I don't know how hot the signal is coming out of your CF, but having a 0.1uF there, and having 0.1uF on both sides of the phase inverter output seems like too high capacitance.
I don't know anything about your input tube stage, but I would lower the CF output coupling cap to 0.02uF.
Offline AHeck
« Reply #5 on: July 15, 2022, 07:23:20 pm »
Of course, you are quite right.  I’ll go and correct that immediately. Good looking out. Thanks.
« Reply #6 on: July 15, 2022, 08:39:52 pm »
Your schematic is not believable. Output tube grid circuit is really messed up.
« Reply #7 on: July 15, 2022, 11:06:52 pm »
470R and 1K should be huge amounts of NFB....
Or Positive Feedback. Can't tell from here.
Offline AHeck
« Reply #8 on: July 15, 2022, 11:18:45 pm »
I was trying to write out the dual 250K pot master volume.  I didn’t get it right, did I?
« Reply #9 on: July 16, 2022, 09:31:33 am »
The key question is, compared to open loop, does the feedback cause gain to be increased or decreased?
Positive feedback doesn’t necessarily result in free running oscillation.
« Reply #10 on: July 16, 2022, 10:16:36 am »
Ah ha! Now it makes perfect sense.
You used a triangle for your ground symbols and you used the same triangle for the pot wipers. But the pot wipers did not actually touch the pot. My mind just processed the pot wiper triangles as two more ground symbols. Sorry for the confusion.   :BangHead:
Offline AHeck
« Reply #11 on: July 16, 2022, 10:29:34 am »
The gain increases when I switch the NFB on.  Did I miscalculate the polarity through the preamp stage?
Offline AHeck
« Reply #12 on: July 16, 2022, 10:32:16 am »
Yessir.  Sorry about that.  I’m still trying to find and install a good potentiometer model on LTSpice.
« Reply #13 on: July 16, 2022, 11:14:18 am »
Feedback that increases gain is positive  :icon_biggrin:
The balanced area of the circuit is usually where mistakes are made.
If you’ve got a scope and sig gen, it’s simple to verify the signal polarity.
« Reply #14 on: July 16, 2022, 12:10:19 pm »
Aside from having positive feedback, the voltage divider options in the NFB loop on your schematic will provide quite a lot of feedback (as someone else already mentioned). With LTP inverters, ‘less is more’. Look at tried and true examples: 820R and 47R (BFDR) or 56k and 1k5 (6G16), 27k and 5k (5F6A). Even too much NFB can result in positive feedback at HF (particularly with output transformers that are wound with several interleavings, where interwinding capacitance produces more phase shift at HF, which can add up to positive FB).
But try swapping the OT primary ends to the opposite output tube plates first.
« Reply #15 on: July 16, 2022, 04:38:57 pm »
Other examples of that type of MV show 2M2 resistors to bias tap. Yours shows 1K8.
That's quite a difference.
Offline AHeck
« Reply #16 on: July 17, 2022, 09:12:58 pm »
Thank you, no more oscillation.  I can max out the Vol, Master and guitar and it's quite quiet and stable.
Offline AHeck
« Reply #17 on: July 17, 2022, 09:49:30 pm »
Yes it is.  There are 1M8 resistors at the wipers of that pot.  Thanks for catching that.
Offline Williamblake
« Reply #18 on: July 18, 2022, 02:04:03 am »
So you heater centertap is connected to 0VDC via a 50uF capacitor? Why?
Offline AHeck
« Reply #19 on: July 18, 2022, 07:16:19 am »
There’s a voltage divider off of B+ at the 47uF Cap. The resulting voltage is a little over 50VDC and tying the heater CT in there elevates heater ground so the Heater to Cathode voltage comes in under the 200V maximum at V2b.  The capacitor to ground helps with heater hum.
